Edge EZ
Edge EZ
I took the Edge EZ off my 2001 and put it on my 2002 (Had to buy a MAP sensor adapter). On my 01, I had crazy power, on the 02 I can't tell the difference, what's up??
Does the same Edge EZ for a 2001 work on a 2002? I remember when I ordered my Edge Comp. they called for the truck year, and told me that my 2001 box wouldnt work on any other year truck.... I dunno about the Edge EZ tho .?.?.?
I called Edge told them I had an 01 and asked if it would work on the 02. They told me I would need to buy the map sensor adapter (part #MAP2002) and it would work.
Electronics for the 01 & 02 are identical... except for the MAP sensor fitting. 02 adaptor is all that's needed. Earlier adaptors are year specific and won't work.
On many of the the 02's, the Data Port is in a different place than on the 01's. Mine is way down below the ECM connector plate. Recheck all your connections... should work fine!
RJ
RJ
Drivers side of the Engine block...just forward, and below, the fuel filter. It's a plate mounted flat onto the block that receives a 50 wire plug!
Look below the front 1/3 of this ECM 'plate' for another wire coming out of the wiring harness (that goes to the ECM).
This is where mine is, anyway.
Don't forget the Data port 'dust' cover has to be removed first. Don't ask why I bring that up
RJ
RJ
