Edge Drag COMP, or TST PM3???
I have a regular Edge COMP sitting in the garage and was trying to sell it in order to get a TST PM3 to stack with my Smary... Which would be better in yall's opinion, to just update the COMP to a DRAG and stack it? Or try to sell it get the TST??? Thanks
it all depends on what your truck likes. there are a lot of people me included that have bigger injectors that make the MOST power with the DRAG comp alone. i have ran all three. smarty, tst comp, and drag comp. i have even ran them in a tripple stack, as far as my truck goes, i make the most power with just the DRAG comp, others have made more power with the TST comp, smarty stack so like i said, it all depends on what your truck likes.
Alright... main thing here is that money is a factor... Im trying to get a lot of power without alot of cost (contradictory i know)... So injectors really aren't in my plans for now
Yea smoke would be great... good for gettin those tailgaters off ya ... But since im stacking it with a smarty it should give me some more... The smarty aint bad by itself
So you have a comp and you have a smarty and you haven't tried them stacked? You might like it, especially since you said you didn't want to spend a lot. Even settings on the smarty like Justin said.
yea i aint stacked them yet because i dont have the clutch to hold it yet.. and id like to get the bigger turbo first so my egts dont run off the map
I've run the comp and I've run the TST before with and without the smarty on both and while I don't have any dyno figures for the comp/smarty stack, I can say that the TST fueled much harder on mine and made a nice increase in power over just the Comp.
I'm gonna have to disagree with ya on that one doug. When I went from a comp to a TST I lost a lot of low end smoke (big plus) and the power came on much smoother than with the comp.
Not knocking anyone but without dyno numbers to confirm gain/loss you just can't tell..... Smoke is just that, smoke. Once you get around 400 RWHP noticing a gain of even 50-100 RWHP is tough.
When I talk about driveability I am also talking about the shudder that the TST has..... No way you could drive a load of animals in a trailer with the box turned up. Yet with a comp it would not be a problem.
