Edge comp upgrade to comp drag
I saw a place that was offering an upgrade for the edge comp box to a comp drag for 125.00 What is gained by moving up to the comp drag?
I'm not abosulotely sure, but I think that the comp drag will raise the RPM threshold for de-fuel from 2700RPM to 3150RPM. As far as I know the only guys to do it are Edge themselves.
Senior guys check me here
![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
it stops the 2700 rpm defuel
having fuel all the way up to 3400 rpms (my last three dyno runs where at 3550 rpms) with the drag comp and the Fuel Preporator is great but...
I just received my 3rd unit from Edge as they have been a problem. Hope this one is good.
Now I wish I had my original one back. (I exchanged it)
One of the three units when plugged in was locked up and when I removed and reinstalled it the truck went into LIMP mode upon starting it and running a mile down the road.
I can say this EDGE CUSTOMER SERVICE has been second to none while trying to resolve this issue.
James
James
If you upgrade to the edge drag you might want to check into a set of injectors. Trust me, i had a edge drag OFF ROAD package and i could tack out at 3550 and 48 pounds of boost, but it cost me 2 injection pumps. contact me for more info HumminCummins@horizonview.net
lvmknsmoke..
08-13-2009 10:59 PM
taken5875
04-04-2008 12:48 AM
mx684
13
07-24-2007 07:52 PM
rockjeep73
03-25-2005 03:34 AM
