EDGE Comp Updates
it gives you a higher hp level, and it makes the truck defuel at 3200 rpm, instead of 2700 rpm....from everyone i have talked to with them it was well worth the $100.
So the current level 5 HPlevel of 120 is raised higher by this update, along with the defueling, and for a 100 bucks? That seems reasonable for basically a better performing unit. Does it do anything to help throughout the various 5 levels? Thanks
i have heard that it makes the other levels alot "stronger" also. and i think the defueling is changed in the lower levels also, if im not mistaken...
I called Edge today. They told me there was a software update for an older unit like mine & it was free. They told me for 100 bucks that they would do the DRAG COMP FLASH. I didn't have my unit in hand with the numbers so they couldn't tell me much, but when I call back tomorrow, I will have my unit in hand, my Edge Unit that is, so they can tell me what they can do for sure. If this is basically like running a Drag Comp, can someone who has run both comps tell me what the difference is and is it worth the 100 bucks? Thanks
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
