Edge Comp With TST PM3 Comp???
Old 10-22-2006, 06:03 PM
dodgediesel's Avatar
Thumbs up Edge Comp With TST PM3 Comp???
Sound like a wierd question but can a person run these chips together? I don't want to run them at the same time but I want to know if I can have the ability to turn one off and use the other one with my smarty. Having both chips installed together, will the two chips cause any code problems???? Does the TST need a boost elbow like the Edge??
Old 10-22-2006, 06:40 PM
natlchamp2k4's Avatar
Dont really know why you would want to do that, the SMARTY/TST stack is really really popular and powerful. Both the comp and the TST do pretty much the same thing. The comp has timing and the TST is just fuel but I would assume both of these boxes would use the same connector somewhere that wouldnt work. The TST is fully adjustable just like the comp.
I think that running the comp and the TST would be like going bird hunting with 2 shotguns, one in each hand, yeah youve got a lot of power, but you couldnt hit the broad side of a barn. Put one gun down, and shoot with both hands. Run the SMARTY/TST stack, its the baddest thing out right now. Yes you will need a boost elbow.
Just sell the comp to offset come cost.
Old 10-22-2006, 08:34 PM
It's just that the smarty smoke is incredibly bad vs the timing from the edge comp (if that makes any sense). Where is the best place (cheapest)to pick up the TST chip in Canada. There is a guy on e-bay that sells the PM3 Comp for $699.00. I just hope the $700.00 is worth the switch???
Old 10-22-2006, 09:43 PM
Well I know with the comp in place you have to use that for timing but why not run the smarty on a lower even number software for daily driving, and run the comp on 1x? for less smoke. And if your looking for top end power then from what I hear no one can touch the smarty/tst.
I think some one with smarty experience could help you more, Im just speaking from what I have read on here
Old 10-22-2006, 10:09 PM
Registered
blackdiesel's Avatar
I sold my edge comp to help off set the cost of the tst.. FYI I got a good deal from jetpoilt (Doug) at PDW, P.S. your going to need more air, while you have him on the line, you might as well take care of that also
Old 10-22-2006, 11:52 PM
possum67's Avatar
dodgediesel i have the tst comp with stock sticks and cant run it over level 2 towing or level 4 with out the trailer with out setting the controler to defeul because of the egts but thats the great thing it will defuel if it gets to hot (turbo/s are coming waiting on funds) sure the comp is about the same way though
Old 10-23-2006, 11:59 PM
kelownadiesel's Avatar
some guys say to run the comp in ez mode(no tap)and use the tst to tap the pump
Old 10-24-2006, 12:36 AM
Ph4tty's Avatar
And you can run the smarty on even softwares if you wanted to run all three. Two boxes and a programmer seems like overkill to me but some people do it.
Old 10-24-2006, 09:01 AM
Ph4tty, what fuel box (beside the smarty) do you run to get excellent numbers like 492/976??
Old 10-24-2006, 09:11 AM
redstreak's Avatar
You can certainly add the TST and use the Comp in EZ mode. That Comp is an expensive EZ box but if you've already got it then you won't have to buy anything else like the Smarty.
Old 10-24-2006, 09:56 AM
Ph4tty's Avatar
None =P
I have a tst but haven't dyno'd with it
Old 10-24-2006, 10:35 AM
Redstreak, I'm already using a smarty. I think it's TST time!!! Ph4tty, that is freaking sweet, I wish I could hit those numbers. I got to suck it up and get those dang expensive twins!!!
Old 10-24-2006, 11:30 AM
Ph4tty's Avatar
If you want power you want a turbo and some big sticks instead of messing around with boxes =P
Old 10-24-2006, 11:44 AM
redstreak's Avatar
Twins are the way to go. Took mine off and bought a single - definitely not the thing to do.
Old 10-24-2006, 01:57 PM
Ph4tty, are you able to tow at all or do you get too hot??
Quick Reply: Edge Comp With TST PM3 Comp???
