Edge Comp and Superchips
Has anyone stacked and edge comp box with a superchips programmer? If so did the truck run ok and could you tell a differance in the horse-power?
You can stack them but I'm not sure how big of a difference you will see. I know with the Smarty you notice a difference because of the low end response it gives you.......but the Superchips doesn't fuel as hard as the Smarty sooooooo I'm not sure??
~Nick
~Nick
I've stacked that combo and yes I could tell a difference. I ran the comp on 3x5 and the SC on the race setting. I turned the comp up to 5x5 once and slipped the heck out of the TC so I never turned the comp past 3x5. Later I sold the SC to get some cash for other BOMBs. Once the SC was unloaded I could turn the comp up to 5x5.
It didn't effect the computer system or any of the electrical system with the two stacked together? People say it is a bad stack because both are timing so I was just wonder. I want to put the superchips back on the truck with the edge comp just for the fact of the tire/speedo change.
That was the exact reason I left my SC on, for the speedo recalibration. And yes there was alot of timing. You can stack it, but I would only use the lowering setting. Mainly because of there will be soooo much timing. When I took the SC off my truck actually sounded a wee bit different.
If I were you I'd sell it and put the money towards other BOMBs...injectors.......
What yr is your truck? Auto or manual? Do you have any other modifications? Fill out your signature so we can see what your working with.
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
