edge comp settings
edge comp settings
if i do not tap the pump wire on the comp box, what is the max power i can achieve? with the sub levels turned up to 5. thanks
Administrator / Scooter Bum
A comp without the pump wire connection will give the same power as an Edge EZ.
I drove mine in EZ mode for 3 years.
Wire hooked up now..............wheeeeeeeeeeeee!
PS just noticed that EDGE needs to use a Spell-Check.........
ok, even thought its on level 5.5 and dumps alot more smoke than the EZ box itself, i am not getting an more power than the EZ.
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
