Edge comp safe driving
Well hi everyone I appreciate everyones opinion and help
I have a Cummins 99 with high ram intake and edge comp with two guages pyro and boost.. I was curious as to what setting on the edge comp is safest and most economical for town driving and what setting is best for hauling a goosneck with about 12 tons of hay...I have a stock clutch brand new and good. I would like to keep it that way if you know what i MEAN
tHANKS
Coorsman87
tHANKS
Coorsman87
If it's a brand new STOCK clutch I wouldn't run the comp over #2 to be safe. That would be about the same as a ez but people have tore things up with a ez towing also. I think you should be alright but go any higher than 2.
You really need to get a fuel pressure gauge ASAP! especially running the Comp. Did you tap the IP?
1x1 will probably get you good mileage. I tow with mine on 3x5 and no problems. When i ran 1x5 for a week i got 17.4 mileage and that's with 4.10 gears.
THanks yall...Appreciate all the info..No fuel pressure guages as of yet but hey am still looking any recommendations as to which brand and type i can use..Keep in mind i have to have a sleek place to mount this guage.,...
Order your FP gauge from Eric at Vulcan Performance he has the best prices and service around.
Did you tap the injection pump wire when you installed your Comp?
tHANKS
Coorsman87
tHANKS
Coorsman87
For economy, you want power level 1, sublevel 1.
jh
lvmknsmoke..
08-13-2009 11:59 PM
mx684
13
07-24-2007 08:52 PM
JD farmboy
05-21-2006 02:04 PM
rockjeep73
03-25-2005 04:34 AM
