Edge comp question
Edge comp question
If I get the edge comp and do not tap the pump wire how much hp and torque will I see at the rear wheels? I am going to wait until my 100k warranty expires before tapping the pump wire and then I am going to use a pump cover.
Tap the wire
I tapped my wire at 11,000 miles and push over 35 lbs at times. The reason I say over is my guage only goes to 35. If you have a decent m\wrench at your local garage he won't care if you have the wire tapped. The only problem is your injection pump it won't be under warranty, as they have to send that in to Dodge. Cummins has rebuilt pumps for around 1500 I belive. For what it is worth tapping the wire is incredible I suggest you do it!!!!! I had a 99 that lost the injector pump at 9000 miles; I think you either have a good one or not just my two cents.
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
