edge comp question.
Registered
Originally Posted by dieseldodge
ill have to check it out. will it hurt to block off the wastegate on a manual trans truck
checked everything out, all tubes and couplers good.checked all connections on the comp, all good. just cant find out why i can only get 25 lbs of boost and thats on 5/5 on the comp. i was thinking, and it only pulled 33-34 lbs for about a day when i installed everything, then fell to 25 lbs max. im puzzled.
Mine did the same thing, Three out of four boot were full of pin holes"used soapy water to find them" It would hit 28-30 then fall to 20-22. I replaced the boots and blocked off the waste gate and now I can get 30-35 on level one with stock injectors and turbo.
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
