edge comp question.
Old 08-19-2006, 01:31 PM
dieseldodge's Avatar
edge comp question.
this may sound stupid but is the edge comp stackable. been thinking of adding a superchip programmer but wasnt sure if i could. if it is stackable, do you recommend a different downloader.
thanks,
jeremy
Old 08-19-2006, 01:37 PM
CSAGrey1's Avatar
Mads Electronis SMARTY downloader available here at DTR.
You won't regret it
I may even know of a Catcher ECM out of an 01 auto for $350 if your interested.
PM for details
Old 08-19-2006, 01:59 PM
Registered
blackdiesel's Avatar
Truthfully, the tst pm3 smarty stack is the best.
That being said, there are many guys on here running the edge comp and smarty. they say it fuels hard and drives great. But ive also herd the tst/smarty is much smoother
i have a tst pm3 comp coming next week, ill post results when i get er in.
oh and dont buy the superchips, not even comparable to the smarty.
Old 08-20-2006, 09:20 AM
displacedtexan's Avatar
It would have to be a no timing Catcher to run with the Comp.
Old 08-20-2006, 09:52 AM
singleturnout's Avatar
what would to much timing do
Old 08-20-2006, 10:04 AM
Registered
hard starts, wouldn't run very well at all, blow HG, etc.
Old 08-20-2006, 10:14 AM
the only reason iam asking is because i had to replace my ecm and i got one from marco and he swears its stock but it idles kind of loopy now.fp is 19 at idle and 17-18 wot so i dont think its my fuel pump ,i also run a comp and just wanted to see if there was to much timing
sorry for hijacking
Old 08-20-2006, 10:19 AM
Registered
if you turn your comp off does it quit? if not, the ecm is either stock or a federal.
and if he says its stock, im sure he belives it is. Then again, theres always that small possibility that something is different with it.
but the lope could have been caused by something else in the ecm, or not even by the ecm at all
Old 08-20-2006, 10:31 AM
so the smarty really sounds like the way to go. im pretty pleased with with the comp but i just would like a little more. i would like to get some more boost out of her. right know, im only getting 23-25 lbs max. when i first put all the stuff on it, i was getting 33 lbs max.
Old 08-20-2006, 10:48 AM
if your looking for more boost you can block off the wastegate or get a adjustable boost elbow
Old 08-20-2006, 10:57 AM
thats what i was thinking of doing. seems like blocking it off would be easier. i had to change the elbow when i installed the comp and it had a smaller hole in it.
Old 08-20-2006, 11:00 AM
Registered
if your only getting 25 now and you were getting 33, you oughtta check your boots for cracks/holes. with my old comp and injectors i could hit 42 psi easily.
Old 08-20-2006, 11:33 AM
will it hurt to block off the wastegate in a manual trans truck.
Old 08-20-2006, 11:34 AM
i dont have injectors though. wont that make a difference in boost also?
Old 08-20-2006, 11:36 AM
Registered
yes, it will, but even so youve lost 8 psi of boost and you havent done anything to it?
Quick Reply: edge comp question.
