edge comp problem
edge comp problem
Had been using my edge drag box for the timing end of things with my smarty and fueling was being used by blue chip box. I wanted to see how edge worked with the smarty when it did the fueling so I disconnected the blue box and hooked the pump wire up on the edge, but the comp box does not seem to be fueling hard at all any more any thoughts?
Ground
Thats what I did,,,
Comp is up 4 sale now... hahahahaha
Good luck..
Not sure if I should laugh or get sick at the thought of my IP blowing up Needless to say I'll try it there, because my blue box was already tapped there to I guess I never even thought about it thanks I'll try it out and let you know
Used one
BUT it did have 209000 miles on it.The one I put on had 92000 miles on it.
So that was the first time I used my AAA in the 3 years I had it,,,, Flat bed ride home to install the used pump,,Cut pump tap wire,,, Install Dodge performance ECM with catcher software in it,,,Sell comp. Get Rv-275 injectors.
Any Difference?
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
