Edge Comp & J hook ?
I havent found much on this subject but Im finally gonna be hooking up my Comp soon & wanted to know if I should get the J hook for my HY turbo? since the kit came with a boost elbow that is made for the HX turbo. Ill be adding Scheid 100HP sticks soon too. thx for any input.
No, the comp has a boost fooler built in. I have Rv275 injectors, a stock auto, and an Edge EZ (basically the same as a comp without the wire tapped). Mine runs great. If you add 100hp injectors, or tap the wire, you'll need more airflow than a J-hooked HY35 can give you. Mine can get toasty when towing with what I have if I run in OD and let it lug.
lvmknsmoke..
08-13-2009 11:59 PM
mx684
13
07-24-2007 08:52 PM
JD farmboy
05-21-2006 02:04 PM
rockjeep73
03-25-2005 04:34 AM
