Edge COMP install
Old 03-10-2007 | 09:40 AM
Awall's Avatar
Edge COMP install
I know some guys leave the MAP unplugged on their trucks.. Does doing that cause the truck to throw a code? and does the check engine light come on?
Old 03-10-2007 | 10:00 AM
CTD_Neil's Avatar
No, as long as you have the COMP installed.
Old 03-10-2007 | 10:02 AM
Awall's Avatar
ok thanks for the help
Old 03-10-2007 | 10:26 AM
B.A.Ram's Avatar
yea I sent mine off to edge for the drag upgrade and my engine light is on...I'm gonna assume it's because the circuit isn't completed...but it runs fine..
Old 03-10-2007 | 11:44 AM
natlchamp2k4's Avatar
Ive got the DRAG comp and I have never ran it with the MAP plugged in. I have had no CEL.
Old 03-10-2007 | 02:01 PM
clinton81's Avatar
I have an eadge EZ pulse on my 98 24vlv. I un-pluged the map sensor and it threw a code over boost. All doing it does is incease your low boost fueling so you throw some smoke untill your turbo can catch up. But after a coulple of starts the code goes away.
Old 03-10-2007 | 09:01 PM
bigmack2500's Avatar
I have just installed my comp and hook up the power inside the fuse box with the clip that goes over a fuse. did away with that because sometime it would not come on, and every now and then i will loose all throttle and it will just idle for a second then kick in. then the engine light will come on but has not done that in a while. After a few starts the light will go off on its own. any tips on my problem
13jy831
02-25-2011 08:45 AM
lvmknsmoke..
08-13-2009 11:59 PM
mx684
13
07-24-2007 08:52 PM
JD farmboy
05-21-2006 02:04 PM
rockjeep73
03-25-2005 04:34 AM
