edge comp with injectors?
Thought you guys might could tell me if the edge comp has a built in boost fooler.....saw in another post where somebody said that the edge ez has a boost fooler built in it.....Also i was wondering what which injectors would work the best with my set up?? i also tow large loads from time to time....
02 HO 4x4 6spd, edge comp, 5" inch exhuast, pyro and boost guages.
Yes it has a fooler and should come with an elbow.
Someone else should give you injector info. I know RV 275's are mild and tow well. I think there's others that give more power and tow well without too much heat.
I have the 275's and the Edge Comp box and have good luck with towing. Not to mention you can get the 275's cheap enough. (Pd $250 for mine about 4 months ago) They will give you good towing power at cool temps if you keep the box turned down off of 5, and some pep in your step when running empty!!
Well i thought about a new clutch, but the one i have seems like its handling the comp box just fine....I really shouldnt complain because this truck is pretty impressive with a trailer behind it....especially compared to the powerstroke i traded in
for it.....Maybe ill try some of the 275's....how much horsepower does that add by the way????
Originally posted by pecandude1
i tried dd1s with my comp box and it was too much for me when pulling but was awsume when solo lots of smoke too. the 275s would probably be better
Get some DD2's and turn the comp all the way down to setting one. That is a great towing combo.
You will be getting a new clutch sooner or later, the stock setup can not handle a comp and injectors. To be honest I am surprised it holds a comp box unless you only run on levels 1 or 2.
Good luck.
Good luck.
My clutch held for about 4 or 5 good 5X5 runs then I started getting a very unwanted air freshener scent in the cab.....but man it was fun while it lasted!!!!!! The savings account is almost ready to be emptied on a new south bend shortly.
Good luck.
Good luck.
Something to be considered is that the HO is likely to blow a head gasket with a box that adds timing and injectors. Injectors work really well with the HO, but since the HO has more timing stock than the SO the combo of an edge comp and injectors can bring you over the edge of what the head gasket will stand. (Even under quite low boost.)
AlpineRAM
AlpineRAM
Say what? Not to challenge you, AlpineRAM, but I've never seen anyone express concern about the HO headgasket either here or on TDR. Did I overlook something? Standard towing recommendation from Wildcat, City Diesel, etc., is an Edge EZ/RV275 injectors, and watch the clutch because it may or may not go.
Edge Comp -- which you mention -- is not only a timing box but a fueling box. Do you mean that the fueling feature -- pinning the wire to the injector pump -- will bring the compression over what the HO head gasket can tolerate?
For my part, I've had an Edge Pulse, RV275 injectors, and an HX40/35 hybrid turbo installed for many miles, towed all kinds of trailers over all kinds of terrain, 25-30 lbs. boost occasionally, no gasket problems, and I've even managed not to slip my stock clutch. Of course, I don't race. . . .
Not disagreeing with you, but concerned that I may have missed something new. Can you offer anything more?
Alpine,
I too have not seen anything until now about the HO head gasket not holding. I've been researching for quite some time now so I don't get bored too quickly with my upcoming purchases. So far it's looking like MachII's and the Edge Comp.
Please enlighten us if you have any more info about the HO gasket.
