edge comp ...doing nothing
Old 11-17-2004 | 08:01 PM
Adam F's Avatar
Angry edge comp ...doing nothing
I just put a new comp box on my 99 cummins and there is no new power... the box lights up and changes settings, but the power stays the same as stock. I'm not sure if I tapped the correct wire on the pump.The directions I got with it were hard to read[blury]so I couldn't tell which was the right wire.The truck still runs just like stock ,with no problems.
Old 11-17-2004 | 08:35 PM
midwestdually's Avatar
even with the pump wire not tapped...there still should be a huge difference...did you get a box that was compatible with your 99?
Old 11-17-2004 | 08:51 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Check here for a downloadable set of instructions.
http://www.edgeproductsinc.com/instructions.html
These should be a noticeable kick in the pants with the wire not tapped (The way I'm still running my Comp), and from what has been reported, your eyes rolling back in yer head with the wire tapped.
Old 11-17-2004 | 09:41 PM
BigBlue's Avatar
That's a pretty good description of the feeling you get when the wire is tapped Shovelhead. You should notice a good kick in the rear end with the wire untapped.
mx684
13
07-24-2007 08:52 PM
Sleigher
03-23-2007 01:23 PM
JD farmboy
05-21-2006 02:04 PM
rockjeep73
03-25-2005 04:34 AM
