edge comp box defueling
I have a 01 2500 with edge comp box and when i nail it from dead stop it seems to have dead spots in it like it jumps through the 5 setings or somthing and wont even slip a tire smokes like hell though whats up with that????
What mods do you have other than the Comp? If you are running stock (especially with no transmission upgrades), as I found out with my automatic, the "dead" spots you describe may be your tranny slipping. What level are you on when you stomp it?
May have a ground problem. Comps are sometimes bad about things as such. Try adding some wire and moving the ground wire to the negative battery terminal. I had trouble with mine and that turned out to be the cure for mine.
Hope this helps...
Paul
A Smarty on level 4 or higher will also fix this issue. The Rad box is cheaper but the Smarty is more fun. Edge products do nothing to the torque management on these trucks.
bwarning01
15
08-24-2007 09:19 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
hellotbone
07-12-2003 12:58 AM
