Edge Comp & boost elbow
![Talking](https://www.dieseltruckresource.com/forums/images/icons/icon10.gif)
Just installed my comp with wire tapped. That was scary, i pulled the truck out of the garage last night and the check engine light came on.
i took it for a drive in the morning and the light stayed on, so i opened the hood to have a look
i found i had neglected to tighten the ground for the wire tap
. fixed it and the light stayed on
, pulled the battery cables checked all my connections and everything looked ok.
Well hooked the batteries up and started the truck and no light went for a drive and WOW
couldn't keep it under 80.
Anyway the boost elbow that came with the comp is it the same as the elbow for my EZ?
thanks
scotte
![Shocked](https://www.dieseltruckresource.com/forums/images/smilies/shocked.gif)
![Crazy!](https://www.dieseltruckresource.com/forums/images/smilies/crazy.gif)
![Duhh](https://www.dieseltruckresource.com/forums/images/smilies/new1/duhhh.gif)
![Mad!](https://www.dieseltruckresource.com/forums/images/smilies/new1/madani.gif)
![Smilie](https://www.dieseltruckresource.com/forums/images/smilies/smile.gif)
thanks
scotte
dodgediesel
14
12-14-2006 09:54 AM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
hellotbone
15
04-19-2003 03:44 PM
