edge comp
edge comp
im new to the site and i just put my edge comp in my 2000 dodge with a 6 sp. it has 90 hp injectors a south bend clutch and 4in exhaust. i have gauges and im tryin to figure out what level to run the comp on for everyday drivin. any suggestions?
My '02 has the Comp and 90hp injectors. It's an auto, but I also run on 3 for daily driving (when I am the one driving it anyway). Seems to have good pep and still gets great mileage with very little smoke.
With my setup and the Juice on 5x5, I'd pull my stock lift pump from 11-12psi down to 5 or 6 psi on a hard run. With injectors I'm sure yours will drop more. I put on a Raptor 150. At an idle and at highway speeds, it sits around 15-17 psi. Hard run, the lowest I've seen it go is 13psi.
I hope you have a fuel pressure gauge at the very least. If not you might be asking for trouble....
I would highly recommend some sort of aftermarket lift pump as well.
And yes I run the Comp on 3x3 for daily driving. Anything more is a bit more smoke than I would like around town.
For the money, I would go with the Raptor 150. It is recommended by some, but you don't have to drop the tank with it. The 150 comes with a quick-connect to hook up to the factory pickup on the tank. I hooked mine up that way and have no issues.
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
