edge comp
Old 02-05-2007 | 10:13 PM
ncdodgeman20's Avatar
Talking edge comp
hey yall i just got few ?s i just installed a edge comp on my truck its an 01 i have got all the gauges and all but anyways i got it ran it without the ip taped for a few days fp neveer got below 8 at wot and egts were good and egt was good but boost was high i saw 30 32 just on ez mode but aint his a little high for stock?and the i taped the ip and the power is awsome but on kill mode fp drops to 5 nad boost jumps up to 40 to 43 fast the turbo has a j hook on it and egts get up to around 1200-1300 at wot so anyways aint the boost to high for the stock turbo?and i want to know what turbo i got it says holset on it and allso the truck is an auto so plaese some let me know if this numbers look right. thanks
Old 02-05-2007 | 10:23 PM
blackdiesel's Avatar
Registered
boost looks right, however you need to wastgate it down to around 35~37.
now you need to get a pusher pump on there to help with your fp.
your egts look in check
have fun!
Old 02-05-2007 | 10:28 PM
taken5875's Avatar
you have a hy35 turbo so save your penny's for a bigger turbo come summer time you will peg 1600* on 5x5 just like me. I need more air
thanks for the reply as far as pusher pump what are some good deallers and i already have the scotty smart fuel lines on also to help thanks
Old 02-05-2007 | 11:54 PM
12valve's Avatar
try taking off the turbo jhook i'm affraid going past 35 psi... after blowing up two stocker turbos...
13jy831
02-25-2011 08:45 AM
lvmknsmoke..
08-13-2009 11:59 PM
mx684
13
07-24-2007 08:52 PM
JD farmboy
05-21-2006 02:04 PM
rockjeep73
03-25-2005 04:34 AM
