EDGE COMP = Check Engine Light
I received the box yesterday the 12th box set off The CEL(check engine light) when on 5x5 I did tap the pump wire and the ground is on the neg terminal of the battery. I got codes po252 & code po253 I had them cleared then drove for about 5 miles on 3x5 then the CEL came back when I floored it it seemed fine until I was running WOT (wide open throttle) then it would cut out and miss and jerk then throw the codes. when I went back to the shop I had only the PO253 code I reset it then turned the comp off and drove about 10 miles like a maniac and the CEL stayed off I think there might be a problem with the box what do you guys think???
2002 auto no other mods
Edge comp + stock auto... start saving lots of $$$ for new transmission.
Or don't buy a pyro and no other gauges and burn up the engine before you kill the tranny.
Jut my 2c
AlpineRAM
Jut my 2c
AlpineRAM
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
