ECM Locked after programming w/Superchips
Old 01-01-2009, 01:12 PM
hdlivestock's Avatar
Well hello and help. I reprogrammed my '98 w/with a Superchips MicroTuner from Safe Tow back to Hi Perf about a month ago after returning from a RV trip. Now I can't reprogram it back to Tow mode. It comes up and says "ECM Locked" and then runs through about 5 minutes of programming and ends up with "Vehicle has tuning installed" But the questions is, what tuning? I'm afraid to hook up to my travel trailer with it in Hi Perf Mode cause I've heard that it can overheat the exhaust. I'm running straight pipe.. So the questions is, how do I unlock the ECM?
1998, 4x4, ClubCab.
Old 01-01-2009, 01:15 PM
Zeus1987's Avatar
did you try putting it back to stock ? i had a similar problem happen to me with my hypertech. there was a fuse on the side of the dash i had to pull.
Old 01-01-2009, 01:17 PM
I can't get into the program to were it asked what you want to tune it to.
Old 01-01-2009, 01:43 PM
Zeus1987's Avatar
try disconnecting the batteries and turn the key on draining all the power from the electronics. let it sit like that for about 10 mins. then hook everything back up and try again.
Old 01-01-2009, 02:32 PM
OldDodgeOwner's Avatar
I didn't find anything in my Superchips manual for the "ECM LOCKED" message, but here's their customer service number 888-CAR-CHIP
Old 01-01-2009, 02:34 PM
97 D-Tec's Avatar
well do you not have gauges to monitor the truck? you shoudl have em no matter what.
Old 01-01-2009, 03:07 PM
I'll try draining the electronics and check again. It's not throwing any codes. What gauges do ya'll recommend. ??
Old 01-01-2009, 05:17 PM
Flatbed24v's Avatar
I like my auto meter gauges, you will need fuel pressure, pyro, boost, and tranny temp
Old 01-01-2009, 08:16 PM
I unhooked the batteries for 3 hrs, hooked my Microtuner back up and same message "Locked ECM Programmed". I don't know.
Old 01-01-2009, 09:57 PM
Zeus1987's Avatar
It sounds like the dealer is going to have to reflash the ECM This is exactly why i dont like these types of tuners .... you just never know.
Old 01-01-2009, 10:11 PM
Tate's Avatar
Call superchips before you go to the dealer to have your ECM reflashed. They should be able to help you out with it, or atleast confirm if you do indeed need to visit the dealer.
Old 01-01-2009, 10:12 PM
scottsjeeprolet's Avatar
Isspro gauges:
Or get rid of the Supercrap tuner and get an Edge Juice w/ Attitude or an Adrenaline w/Pulse. You can also see my Pulse in the pic.
Old 01-01-2009, 10:38 PM
Zeus1987's Avatar
i second that, i found out that the edge on lvl 1 makes more power than my hypertech on lvl 3. the only reason i still have the hypertech is for reading codes
Old 01-02-2009, 07:22 PM
fiveology's Avatar
Originally Posted by scottsjeeprolet
Isspro gauges:
Somebody's got a little too much crap to look at while driving down the road. At least you got them nice bright new headlights now.
Old 01-03-2009, 10:51 AM
high bid's Avatar
wow, looks like the cockpit of the spaceshuttle.
If you can RETURN the Superchip!!!! and go buy a quad XZT+ same power levels, better customer service and you can download tunes specific to your needs for free all day long and as many times as you want to find what works best for you. I've been down the same road you're headed. If you can't get the schip removed from your ECM you will have to have it re-flashed at the dealer, just as I did. Yes, very important to get gauges, I have the commander and it's worked really well but there's tons of options out there, just make sure you install the main 3, trans, fuel psi, and egt(pyro).
Quick Reply: ECM Locked after programming w/Superchips
