EBAY MACH3s WHAT SHOULD I DO???
Old 08-24-2007 | 05:03 PM
lotero's Avatar
so i bought some MACH 3s off of EBAY from a guy who said he stepped up to twins and MACH 6s. what do you guys think, stick em in and fire her up or get em pop tested/checked out??? im thinkin of just stabbing them this afternoon and letting her rip...
Old 08-24-2007 | 05:32 PM
Tiger Rag's Avatar
You can send them back to Don and he'll check them out for you. As long as they are really F1 injectors, he won't charge you.
Old 08-24-2007 | 05:50 PM
lotero's Avatar
thats some good info thanks man!
Old 08-24-2007 | 07:13 PM
firemandodge's Avatar
I saw those last week, looks like you got a really good buy on them to me.
Old 08-24-2007 | 07:22 PM
Mike D's Avatar
Every pair of injectors that I've heard about going back to Don checked out fine. For a free check up I would send them just to have peace of mind.
Old 08-24-2007 | 07:25 PM
Mike D's Avatar
I was looking at your dyno numbers, lotero. Did you make those number with the DD3's? That's insanely awesome! What kind of dyno?
The best I've done is 527 uncorrected with 4.5's...
Old 08-24-2007 | 07:30 PM
Destination's Avatar
Not to jack the post but do you need any special tools to replace injectors
Old 08-24-2007 | 10:22 PM
scottsjeeprolet's Avatar
Only one is a stubby 19mm and or crows foot for #6 injector line.
Use the valve cover bolts screwed into top of the injectors to pull them out. Make sure you pull back the cross over tube before pulling the injectors.
Old 08-24-2007 | 11:12 PM
thanks scottsjeeprolet.
Old 08-25-2007 | 12:01 AM
Tiger Rag's Avatar
No problemo. I think Don likes to check them out to see how his product has been lasting out there too.
Old 08-25-2007 | 12:30 PM
Timinva's Avatar
DTR Advertiser
Yes Don will check them if they are Machs. If you need to send them let me know and I will set it up for you. Matt hows your truck doing? Tim
Old 08-25-2007 | 08:19 PM
Tiger Rag's Avatar
Great, thanks for asking Tim. I love the new South Bend 3850 sprung hub. It is awesome! Hard to explain, but it is the best clutch I have ever had by far! Pedal pressure is still not bad at all as far as I'm concerned. Still very streetable to me, reasonably comfortable engagement but she does hook.
Old 08-26-2007 | 09:49 PM
lotero's Avatar
well there are two things i have never claimed to be, that is smart or patient... with that being said i installed them, idle is rough and it dies from time to time when i put it into gear.... runs like a sunumabish though! so i have to pull them back out stick my DD injectors back in and get em checked
Old 08-26-2007 | 09:55 PM
When we have had that kind of problems it was usally a loose injector line, make sure they are all good and tight.
Old 08-27-2007 | 12:57 AM
hink's Avatar
Yeah, but at least ur honest.
Mattster
07-20-2008 02:55 AM
AlpineRAM
04-25-2007 01:26 PM
tywebb3
06-24-2006 12:30 AM
SjLingenfelter
09-13-2005 11:38 PM
Quick Reply: EBAY MACH3s WHAT SHOULD I DO???
