Easy 12v Mods???
Easy 12v Mods???
I just purchased a 1995 12v and I need to get crackin on the cheap & easy mods. This will be a play toy and will never get hooked to a trailer. I just want it to go fast and pull hard. I am only familiar with the 24v VP44 trucks. Thanks
Josh
Josh
Grind the fuel plate into a #0, loosen the starwheel, slide the AFC housing forward. That'll get ya started. Get some gauges, advance the timing, and buy a 4k to put in it, and that will help it out a lot too.
can you guys describe your recommendations a little better please? I just got a 96 3500 and am in the same boat as the poster.
thanks in advance (ps- mine WILL pull a gooseneck with about 6000k on it)
Before going too far on HP mods get a good valvebody and tourqe convertor for the tranny. You have to get the HP to the ground for it to be effective. If you do the 4gsk do the valve springs too.
OH BTW check the KDP!!! It may or may not have been taken care of.
91TURBODIESEL
10-28-2005 06:46 AM
GotBoost?
16
01-03-2005 08:53 AM
greasy
09-07-2004 06:40 PM
