Easiest place to hook up FP gauge?
Old 04-06-2005 | 06:35 PM
caleb c.'s Avatar
I am still undecided on were to plumb in the fp line.I guess my options are-schrader valve,bottom of fuel filter canister or tapped banjo.I was planning to go the schrader route.My problem is this,the isolater has a 1/4npt thread hookup on it and then the hose needs to go down to the schrader valve.But I can't seem to find a hose like this.What should I do?I am running a Di/pricol fp gauge.The isolater outlet as previously stated is 1/4npt.Aren't most of them 1/8npt?
Old 04-06-2005 | 07:03 PM
MtnCamper's Avatar
I ordered a tapped Banjo bolt from Geno's. That will go on the fuel line at the bottom of the filter. He also has a 18" long hose, that would go directly onto the Schrader, and depress it. But he is out of stock until the 22nd.
New bolt and 2 washers + shipping $10.
Old 04-06-2005 | 07:16 PM
bws's Avatar
bws
shrader valve,theres two. one on vp44 and one behind the fuel filter..just takes a tire stem removal tool.brad
Old 04-06-2005 | 07:20 PM
RAM2940's Avatar
I got the tapped banjo from geno's. Tapped into bottom of fuel filter. Installed a shutoff valve and followed with a 1/4 to barb. Got 2ft of hydraulic line(rubber hose 1/4 diesel rated) and put a push lock(barb) to 1/4npt. Ran ss braided into cab to guage. By going off bottom of filter you can double check pressures using shrader valve if needed.
Old 04-06-2005 | 07:23 PM
dodgediesel4x4's Avatar
Which ever way you go, you might run into the notorious "buzzing noise" but maybe not, since you are running the isolator. If you do get this buzzing, try re-routing the fp line to another source. This technique has somewhat lessened my buzzing noise.
Old 04-06-2005 | 10:34 PM
caleb c.'s Avatar
Will fuel leak out after I remove the schrader valve?And,will I need to prime the system or anything?And does the line just screw in to the schrader?Sorry to keep asking questions,i'm just trying to figure this all out.Thanks guys
Old 04-06-2005 | 11:36 PM
MtnCamper's Avatar
Caleb, Check your Private Messages.
Old 04-08-2005 | 03:17 PM
amnewsom's Avatar
I would like to know the same info, after lots of searching on TDR also no one mentioned it. Answers anyone?
Old 04-08-2005 | 10:50 PM
MtnCamper's Avatar
Yup, a little will leak, hook up the hose and put the other end into a container, hit the lift pump, remove the air, and put it together ASAP. You may have to crank a few turns extra, but works OK.
Old 04-09-2005 | 01:36 PM
BCobb's Avatar
I'm installing a fP gauge and the instructions say to fill the gauge and isolater with a liquid. So what type of liquid, any ideas ?
Thanks
Old 04-09-2005 | 07:49 PM
phox_mulder's Avatar
Most use antifreeze.
phox
Old 04-09-2005 | 07:50 PM
caleb c.'s Avatar
Antifreeze Is what most guys use I think.
Old 04-10-2005 | 05:43 PM
tool's Avatar
Why antifreeze??? Why not diesel?
Old 04-10-2005 | 06:41 PM
The purpose of the isolator is to keep fuel out of the cab.
Filling it with Diesel defeats this purpose.
IMHO, get rid of the isolator, they just fail and leak anyway.
Just make sure the guage can handle Diesel going to it.
phox
Old 04-10-2005 | 07:17 PM
dieselnut55's Avatar
Yes, but on a 92? Why worrie
Bobcat698
09-14-2007 11:20 PM
Bobcat698
05-24-2007 12:01 AM
electrifried
10-11-2006 05:37 PM
DieselBoost
04-14-2006 12:22 PM
