E Rated Tires!
E Rated Tires!
hey guys, i just wanted to know if anyone is running discount tire brand PATHFINDER AT? i saw them on there web sit, 285/75/16E 4 tires mount, balance, road hazard and 50,000 mile warranty for just under 700.00 out the door. what do you think pros, cons, any bad experiences out there? thanks mark
Originally Posted by getblown5.9
if you have the money...the BFG AT is now e-rated in the 285/75R16 size and that is a very good quality tire but you pay for them at about $200 a piece
You couldn't pay me to put BFG AT's on again. I've ran them on 2 different trucks and the price does not out weigh the quality or lack there of or tread life, horrid in mud snow and ice. Both sets were siped as well.
i used a few set of Pathfinders years ago. seems they had a short life span back then . belts would go bad and you could not drive without shaking. Tread always looked like new.
I am still buying from discount because they have always stood behind everything i bought there.
had a set of Perrellis put on 10 months ago and just had them replaced . went back to the Michlons, best tire i have used yet
Originally Posted by marks2500
pro comp tires are nice, but i need a towing tire that is load E, with a little bite for on and off road use. anyone using this tire?
I am in the Denver area.
thanks for the replys guys, i priced the bridgstone dueler a/t, 40,000 mile warranty,(900 out the door), the michelin ltx m/s, 60,000 mile warranty,(900 out the door and the pathfinders as mentioned above. i tow heavy so i want to make sure i spend the money right the first time. any other thoughts are greatly welcome. mark
Nitto terra grappler also just came out with a e-rated 285/75-16. I think ive seen them priced around 160 per tire. At discount tire on the internet. Also have the 305/70 -16 in the e-rating, same height just wider.
Not too bad in the ten ply rating, actually better than the BFG's ive had.. (stiffer sidewalls perhaps due to ten plies) Got 45K out of them with no rotation... No complaints about mileage with BFGs, just traction was not all that in the mud. Sand they were great tho..
Tx
At 80K I'm on my third set of tires. Stock it had Michelins, I put a new set on at around 38K. At 78 they were getting down there (4-5 32nds) so I went with Remington E rated Wide Brute RV. First week they were on we went on a 3K road trip. All was well, nice ride, no excessive noise.....thought I'd done ok, until I hooked up the trailer. Pulled the race rig and you could definately notice more sway in the rear of the truck. That was with 75psi, so I upped them to 80. Made them a little better, but I'm going to get Michelins when I need the next set, towing they were much better.
I can as I'm rounding a cloverleaf with no load what so ever feel the truck sort of slide/flop as I call it on the tires - no the tread is not slipping it's showing me that the sidewalls are soft as heck. Again bypass these tires... But that is just my opinion... I can't wait until I can afford better tires but "Management" has not released the approval yet so for me I'm stuck in Pathfinder fun until next spring... I'm trying my darnest to burn them off every chance I get so that I can speed up the re-tire project... On the upside they do roll smoke pretty good
05-29-2009 10:24 PM
buddy26
47
01-04-2007 08:25 PM
sakisaki400
23
12-31-2006 10:17 PM
danshsss
11-23-2004 10:40 AM
