Dynoed the truck
Yeah, I enjoy the early spool and that's why I've swayed from a turbo upgrade thus far. I think twins are the only way I'd be satisfied but I need o-rings and studs first.
I think I might be close to an ideal mild setup as is. I can actually watch the EGTs drop from 1200 to 1100 when the turbo spools, but by then it's rocketing past 35psi on its way to 40+, then the pyro needle direction changes back the other way until I let off the throttle. Maybe if I could play with the wastegate to keep the boost at 38 I could keep the EGTs in check. I'm sure some work with a die grinder on the manifold and turbine housing wouldn't hurt either.
Yup! Well done! Nice results for what you have.
Something like a PS62/14 (if not going higher on HP) would spool as fast, run cooler, smooth out the graph and add 30 HP!
I think your still overfueled. JMO.
RJ
RJ
BigJohnston
24
12-27-2007 03:22 PM
PourinDiesel
69
08-29-2007 11:45 AM
VikingDiesel
19
04-23-2007 04:22 AM
goodeyesniper75
16
08-14-2006 05:58 AM
