dyno #'s very disappointing HELP
Meatball, after I put my htb2 on, the intercooler hose right after the turbo liked to work itself off on one side. I still had decent boost, but wasn't making what it should. Just an idea.
Originally posted by Meatball
DAVIDTD - peak hp 2800, started dyno at 2000, turbo starts lighting at 2000-2100 only a 4 hp difference from 4th to 5th gear dynos. like i said the dyno was giving junk readings all day. but nonetheless there should be alot more power than what my backside is feeling.
Does your "butt dyno" agree with low power?
Typically dyno's don't give junk readings. I agree I would have expected more power than 416hp with your set-up. But if the dyno was a DJ248, the truck lit on the rollers (which based on what I am hearing it did) then that is all that was applied to the rollers.
I would start looking first at things like fuel filter (I've seen large HP increases just by putting a new filter in) Wastegate settings (which if lazy you might see on the graph). If the smoke is there on the street and during the run, I'd look at Wastegate setting. Isn't that turbo good for 50 psi?
As far as everyone being unhappy with numbers, were they uncorrected or corrected. You get a hot humid day and run uncorrected, you WILL have unhappy folks coming off the rollers.
Just trying to help...
CoolumConst
39
09-16-2008 06:24 PM
Smkn600CTD
29
02-05-2006 05:53 PM
