dyno #'s very disappointing HELP
i dyno'd at carlisle 416hp at 798ft/lbs whats wrong somethin isnt right, i noticed i fdont have the power i should, my sledpuller 66 is only goin up to 36 psi with a smaller boost elbow! maybe the injectors are still the problem, anyone know what a 7 hole, 10 thousandth injector is rated at i was told 150. anyone have any help. pleaseeeeeeeeeeeeee!!!!
p.s i was told the dyno was junk by serveral ppl, but still theres a lack of power and boost
36 is plenty. With a B-1 ( Steroid version ) 38 PSI makes over 600HP with Mach 6+ size injectors and the COMP or Redline box. Or about 440 with no box.
Sounds like the box is cooked to me.
BTW, injector hole size has next to nothing to do with performance when talking about injectors.
Don~
Don~
did you try a pull with the box off?? Like Don M said hole size almost nothing too do with power.....if i am correct (Don can tell me otherwize) But i think pop off pressure and atomization pattern are the big factors in an injector....maybe yours arent set up correctly.
JMHO
Jon.
JMHO
Jon.
how fast did you built up your boost........when i was trying to hunt down my power problem i didnt realize that i had only 10+psi after 2200 rpms and would top out at 36psi. took my truck to a local diesel shop and he told me the turbo is shot and when we looked at the turbo the cartridge had play in it and there was a ton of oil all over the intake of the turbo.....
Don~
Don~
It's all about the QUALITY of flow, not just quantity!
Keep that in mind when you are trying to R.E. Don's injectors, like everyone else seems to be
I guess it's a compliment being a target-- it means you're on TOP!!
Gotta love these schmucks that think an injector is just X number of holes of Y diameter at Z angle.
But I digress.
Needingsomecoffeeandnotinagoodmood
jlh
Originally posted by Meatball
turbo is clean, no play its only 4 days old, so i hope its not bad.
RAMTD- i run with the box off alot its nice but the box is noticbly "working"
Hohn, Last time I checked this site is for learning and information. I don't think people appreciate being called schmucks because they don't know as much you or others. JFYI industrial injection builds a good injector and has been doing so for years, not to say there isn't something wrong with meatballs, but I doubt it.
jlh
jlh
Do you know what Don's injectors flow?
You do have to have quantity of fuel, and along with that quantity is the way it is delivered.
Justin
ok calm down guys, i know my way around an injector i wasnt saying just because it flow like a garden hose doesnt mean it will make power. all im saying is of all the injectors around, most usually get somewhat close to advertised hp. which is what im saying. II is a great company. Dont call me a jacka## cuz i asked a question. I JUST WHAT TO KNOW WHAT POSSIBILTIES COULD RESULT IN THIS POWER UNDERSTATEMENT. I think i am goin to don M's but hey some of us can alway afford the best.
DAVIDTD - peak hp 2800, started dyno at 2000, turbo starts lighting at 2000-2100 only a 4 hp difference from 4th to 5th gear dynos. like i said the dyno was giving junk readings all day. but nonetheless there should be alot more power than what my backside is feeling.
