Dyno run
Dyno run
I'm new to posting on here, usually just read what others have to say..A lot of good info on here.. Went to Dynomite diesel yesterday and ran on dyno. Made 360 hp and 874 ft lbs., I thought I had the hp pretty close, but that's way more torque than I thought. Just have an edge ez, and 75 hp injectors. Does this sound right?
To be honest, I guess I'm not sure, I didn't really ask them a lot of questions. Is there quite a difference in numbers? Should I call them and ask?
Cool, thanks. Yeah, I was really surprised to see that much. Guess I should be saving for a clutch. Oh, man! Where to stop? These things are too addicting..
Numbers sound almost too good to be true. 200 stock the ground, that means you picked up 160 HP from a 60HP EZ and 75HP injectors. Your truck made 25 more HP, maybe from the FASS! Just kidding, great numbers though.
Indeed. With my old setup (EZ and DD2s) I once dynoed a suspicious 390/918.
Later, without the ridiculous cf, I did a 346/~840.
It's best to use uncorrected numbers, imo-- but many shops won't give them out (generally lower is bad for business) or simply don't know how to get the raw data (sad to say!).
jh
Not to hijack but give me a real simple run down on difference betweeen Corrected and uncorrected? Besides the obvious why? Remeber simple like if you were explaining it to your girlfriend
So 500 hp @ 35% humidity, 93 F SAE 1.01 would actually be 495 uncorrected hp. On a dynojet there is a menu to select the correction factor before printing the graph.
Thanks ive been reading all this info between phone calls. Arnt there two kinds of dynos what kind would be better to go do a run on i am really curious about what i am turnning?
Any guess at what i am making with my mods?
SOrry for hijacking the thread.
A Dynojet will give yo the best ballpark to where your at compared to everyone else, Mustang, Superflow dyno's are load types and the numbers can be skewed as to where on a dyno jet they cannot be. Do you not know if you have injectors in it or not?
ppsi
13
04-13-2004 03:49 PM
