Dyno Numbers 3kGSK vs stock fuel curve
Just curious if anyone has a dyno for an identical truck before and after a 3kgsk install.
Any 12v will do i'd just like to see peaks and numerical outputs at various engine speeds.
Here's my thought; if i get the gsk i'm just going to be tempted to put the truck into the higher rpm's where fuel efficiency is least. I just want reliability with maximum fuel efficiency and a reasonable increase in power while towing ~6k lbs.
Right now i'm thinking 10 plate, timing bump to 16 and a shift kit in the short term.
Currently i have a 97 with a scotty2, cat and muffler MIA, egt and tranny guage.
Any thoughts/ critiques?
I can try and find my dyno sheet. My numbers were low due to my slipping tranny. If you do decide to mod it I would definately consider a good valve body over a shift kit. Then start saving for a tranny.
johnstra
22
02-27-2006 10:48 PM
winner172
01-04-2005 04:22 PM
Dufrain
29
11-15-2004 05:00 PM
