Dyno numbers
Dyno numbers
Numbers are in 5th gear, on a mustang dynamometer uncorrected @ around 5000' elev. In Bluffdale UT.
Edge setting
#0 260.1 Hp 563.3 Tq
#5 337.8 Hp 757.6 Tq
#6 341.9 Hp 755.9 Tq
One hundred dollars for #6
Edge setting
That is probably 25 hp and 50 tq further into the RPM band. Meaning that your hp curve will hold 25 more horsepower longer instead of dropping off very quickly after the peak number.
Maybe on torque but not on hp. If you have the clutch to hold it, 400-450 is just an injector swap away. You'll probably need something bigger than 2's to hit 500. I too set a goal of 500/1000 and have yet to hit it on the hp side even with mach 4's,....... unless you round up
sCreamin400
11-02-2008 01:46 PM
Diesel Dave
01-10-2003 12:08 PM
