Dyno Numbers
Registered
I'd hope so with a tst comp and meth, not to mention the m6's
I need to get back on the rollers =\
So what settings did you use for the other pulls and how did they work out? Were you spraying? Was there a correction factor?? Gonna post a graph? Gonna get sick of all my questions??
I know you're probably busy swapping vp's right now so git-r-done![roll](https://www.dieseltruckresource.com/forums/images/smilies/roll.gif)
![Shocked](https://www.dieseltruckresource.com/forums/images/smilies/shocked.gif)
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
yeah i used a few other settings. sticks only was 379 or so. The tst on nine and the injectors was 440 (at this point i was very scared
graph is wating to get approved
sprayed the whole time (mixture of -35* washer fluid and a bottle of HEET)
how much do yall think ill gain over swapping vps?!
I have always been told you DIVIDE by correction factor! But do it either way; in your case the numbers will be accurate
An argument can be made for posting non corrected #'s on a turbo charged engine. But let's not go there, now!
Nice numbers!
RJ
Nice numbers!
RJ
I use Racing Methanol (buy 5g Jug from Hiperfuels in Houston) and mix with distilled H2O from Walmart. Can make 10 gal of 50-50 for about $85.00.
If interested.... http://www.goestores.com/home.aspx?Merchant=highfuelsn
RJ
+61 hp with the tst for 440
+89hp with the smarty and meth for 529?
It looks like 95Ram's prediction of 180 hp with sticks on the ho pump held true, so you ought to have another 40 hp there with the so pump.
Yup, You can run heat! If you call Snow they will tell you if you dont have boost juice buy a gallon of washfluid and add a bottle of Heet! I think thats the right mix....
