Dyno Jet 248 ?
Old 03-22-2007 | 03:05 PM
dzlfarmboy's Avatar
Dyno Jet 248 ?
Called a place fairly close that has one. Is that the right model to dyno modified cummins on im pretty sure it is but i've heard of some 248C and 248H
and wasent sure what the difference was. Thanks Brett
Old 03-22-2007 | 03:13 PM
pmtg's Avatar
there on "X" now...http://www.dynojet.com/automotive_dy...yno/index.aspx
i think theyre just revisions and whatnot. someone correct me if im off base...
edit: after reading the first sentence on that page, its an updated 248C. i think if its "248" you should be fine, but the shop owner dropped a lot of coin on that machine so they are your best bet!
some may argue you should be on a load dyno
Old 03-22-2007 | 03:21 PM
dzlfarmboy's Avatar
Yeah just from most opinions people say dynojet is the most consistent reading dyno, ive only been on 4
Old 03-22-2007 | 05:03 PM
RowJ's Avatar
Dynojet 248C is the one you want!
The 'C' means it's a Chassis Dyno. They also make engine dynos and portable dynos. Not heard of the 'H'?
(just saw link above...it's probable all in there!)
RJ
Old 03-25-2007 | 11:24 PM
joefarmer's Avatar
H is the heavy roller (10k lbs? vs. 7k lbs). W is the wide version. 248HW is the nicest non-load cell for duallys with large singles. The Dynojet's with loadcells will load any truck (which helped load the dmax to 1000hp).
bnraond.
jetlife
01-02-2008 09:03 PM
Bad Ramer Jamer
02-22-2006 05:56 PM
Zino
26
08-09-2003 02:01 AM
moneypit
22
07-10-2003 08:36 AM
spitzair
11-20-2002 01:08 AM
