DV sizes
DV sizes
So befor i go to 370s i should do delivery valves but what sizes are most people running , who has the best, and what prices am i looking at.
delivery valves
Your 95 auto would have come from the factory with 131 delivery valves. In my 94 auto i run bosch 300hp injectors and 181 valves . If i would have just run the 300's with the stock 131 DV's i would have had a lower rpm stumble from 900-1300 rpm but with the 181's it runs great. If you go with the 370 injectors you will need at least the 181 DV's most people run the 191 DV's with them. I think the 181's would do the job for you but if you are buying the DV's new the 191's are usually cheaper to buy 230.00 - 250.00. I got lucky and picked up my 181's used for 125.00. Hope this helps you out ask if you need more info.
Rattlerbob
Rattlerbob
