Dump Valve for the sake of it!
Old 05-03-2005 | 11:40 AM
kurtwalton's Avatar
Hi Guys, I like the sound a dump valve makes and was wondering if anybody had fitted one to the Cummins, I know it wont make any difference power wise but the noise is cool. Any thoughts would be great.
Thanks Kurt
Old 05-03-2005 | 12:07 PM
1320's Avatar
I ve thought about it......mostly to see if the egt would go down when say pulling a big hill when towing. Like two 3 inch electric cutouts off the bottom of the down pipe, and run them out the passenger side at the front edge of the door. Kind of alot to spend (200 for 2 3 inch cutouts) when I have plenty of power anyways and low egts already.
Old 05-03-2005 | 01:02 PM
jimjawz's Avatar
By dump valve do you mean a blow off valve?? I f so I have a bov on my ctd.
Chk my pics for some ... um, pics
Old 05-03-2005 | 02:24 PM
gunracer1's Avatar
like this
Old 05-03-2005 | 03:38 PM
jimjawz's Avatar
How did that fella accuate his bov..???
Old 05-03-2005 | 04:19 PM
Marine's Avatar
What is the purpose of a BOV on a diesel?
Mike
Old 05-03-2005 | 04:29 PM
seabee's Avatar
marine ,
the purpose of a bov on a diesel is to keep the boost pressures under a set psi ie set it at like 50psi so you dont have to o ring the head . so that the waste gate and the bov work together . just in case the wate gate doesnt catch all the boost . well thats how i understand it noramlly seen on a truck running twins or a bigger single . were if its not there the turbo can make big boost numbers ie upwords of 65psi
Old 05-03-2005 | 04:34 PM
Forrest Nearing's Avatar
to prevent barking the turbo when letting off at high boost... not really necessary on an automatic. boost will recover on shifts quicker w/ a manual tranny truck.
Forrest
Old 05-03-2005 | 04:43 PM
Marine's Avatar
Roger that.
Mike
Old 05-03-2005 | 05:23 PM
cumminsdriver635's Avatar
JimJawz: Nice truck
Eric
Old 05-03-2005 | 06:13 PM
Originally posted by seabee
marine ,
you're thinking of a pressure-relief valve... often called a "pop off valve"
Forrest
Old 05-04-2005 | 12:42 AM
jimjawz's Avatar
Originally posted by cumminsdriver635
JimJawz: Nice truck
Eric
Thank you very much.
The bov does a few things. It can be set for a certain amount of boost, and it can prevent turbo bark and most importantly... It is so cool to make it blowoff next to another ctd,or a powerstroke,or any ricer you want because they all love turbos. Mine is accually controlled by a button on the shift ****. So when I am at wot and about to defuel at 3000 rpm, I push the button and wait for the woooooooosh...Then shift.
johnny5.9
05-07-2015 11:43 PM
capt.Ron
02-25-2014 08:52 PM
hotdram
05-24-2006 07:12 AM
halerazor
09-13-2004 05:46 PM
thumbs
08-06-2003 01:39 AM
