Dumb Question....But still lwould like to know.
Old 01-19-2009 | 01:27 PM
kellen23's Avatar
I have a edge juice with attitude and was just wondering how to hook that up to read your fuel pressure, I know its not working since it reads 33 constently. Just put a airdog system on my truck and would like to moniter my pressure.
Old 01-19-2009 | 02:07 PM
klx650a2's Avatar
I've heard of inconsistencies with that. Go with a mechanical gauge off the IP and a low pressure light...
Just my over rated .02...
Old 01-19-2009 | 03:09 PM
kellen23's Avatar
I was wondering if that would be the way to go, probably easier to install
Old 01-19-2009 | 03:13 PM
tx_2500's Avatar
Check the online installation instructions from Edge. Its pretty easy, you just have to replace the banjo bolt on the very top of the fuel bowl with the sender unit supplied with the kit. It may or may not be as accurate as a mechanical gauge, but its better than nothing and I dont have to run fuel lines into my cab....its good enough and its saved my butt before.
Old 01-19-2009 | 03:35 PM
kellen23's Avatar
Ive got a different lift pump so that banjo fitting is gone. I think I will just get a mechanical gauge put in
Old 01-19-2009 | 08:27 PM
clarson80's Avatar
find a cheap mech. gauge on line, and buy some fuel line and fittings needed at a hardware store. Make sure to use a shutoff valve somewhere in the line so you can use it as a snubber to get rid of pulses in pressure. (hard on the gauge, I found out the hard way and had to put in a new gauge.)
Mopar1973
08-13-2012 09:23 AM
freight train
06-29-2010 11:58 PM
Jordan5687
07-01-2007 09:19 PM
cheapskate
13
01-26-2007 09:12 AM
