dual pics
Re:dual pics
[quote author=BigBlue link=board=7;threadid=6012;start=0#54823 date=1034973805]
Go with the dumped look. Makes for a nice sound and clean looks.[/quote]
Maybe sounds nice, but if you run alot of fuel the underside of the truck will quickly turn black. And it will be a pain in the rear when you actually have to get onder the rear axle for service, or need your spare. Just my opinion. You might decide the same thing when your able to create smoke at will.....
Stroke This......would you consider modifing that picture to make it smaller? 183k in file size is a bit big for the dial up guys, not to mention the 1280x960. It don't bother me none because I have cable.
Re:dual pics
Actually Kat, I have a turndown tip on mine so it dumps it underneath and to the left a little. I had it set up that way cause at 2100rpm, there would be this amazing reverberation inside the cab and out and it sounded beautiful. ;D Couldn't hardly hear the radio. But with the turndown tip and the Comp on 1x5, there is no smoke on the underside. Even with the wire hooked up and on 3x3, no smoke on underside.
Re:dual pics
[quote author=BigBlue link=board=7;threadid=6012;start=0#54836 date=1034976350]
[/quote]
Thats why I said "when" you can smoke at will. You say you want more power oneday (12's) and thats gonna require bigger injectors which will smoke with the box OFF and if you go big enough they'll smoke at idle. A COMP alone will not make "that much smoke" ...on stock injectors and the HY35.
[/quote]
GotStacks
05-23-2009 01:08 PM
DNRCustoms
11-11-2008 09:25 PM
