Dual Exhaust
MBRP sells a realy nice kit (Cool Duals) that I have helped put on for a few guys but it has to be a 4X4 (for clearance with out some mods) but you can keep your spare tire.
This is not an add just letting you know what part#'s I found for refrance when I was looking for a set.
MBRP 4" Cool duals Part #
T-409 Stainless 94-02 (S6102409) $731
T-304 Stainless 94-02 (S6102304) $1,147
Aluminized 94-02 (S6102AL) $575
The Aluminized is fine as long as you are not in the far north east with a lot of salt on the roads. The duals are too $$$ for me I just got the 5" for a lot less. But if you want duals MBRP is the way to go.
RPMoutlet.com sells the Moto Blue pretty cheap. I have had mine for about 2.5 years and Fiveology just put one on not too long ago. If you run the stock spare it will fit. I've also put on the Silverline and none of them go in easy. Getting everything to line up is a pain, the instructions leave a lot to the imagination.
I purchased the BD duals over a year ago, no problems what so ever. Was also looking at the mbrp duals. The BD is stainless, and was $400 cheaper than the mbrp stainless. I found the the mbrp hung a little bit lower on the exit. the BD is nice and tight like the stock exhaust. But I can not run the spare tire underneath. I run 285/65/16 tires. hope this helps.
GotStacks
05-23-2009 12:08 PM
DNRCustoms
11-11-2008 08:25 PM
