dual disk rebuild
dual disk rebuild
So i am looking into buying a dual disk because i snapped the input shaft and i took a look at my clutch and the valair does not look so hot my flywheel is scared pretty hard along with pressure plate and some ceramic is gone but not slipping yet. Anyways jusy wondering what rebuild cost is of a dual disk just a guess because it sounds like if you pull and you use it hard it needs looking at after a year or so.
It depends on how bad it is, but mine cost me $700. but i bought new disc's because i switched to a different material. Basically though, you could buy the new parts you need and put it back together. I would reccomend having it done though because ther is little things like adjusting the clutch fingers for proper disengagement and other things to try and make it last as long as it can.
cconrad331
01-27-2008 09:47 AM
DSjockey
34
07-20-2007 07:03 PM
