dtt tranny shot??
dtt tranny shot??
i have a 2001 ctd with a dtt overhual kit done by power by poole well after i got in install i was supposed to take it back in and get serviced well i fianlly got around to takeing it in at 25000 miles after install well things didnt look to bad well it has been service twice since then every 20000 miles well i just done it againe about 2 weeks ago and did fine for about 3 days then it stared acting like it was huanting for gears between 1 and 2nd then i got to were i didnt want to shift into third without you haveing to let off of the throttle well now i wont shift into third none so i readjusted the bands and all and stilldont work so it huants for gears in first and2nd and now i wont shift into 3rd and fluid is 3 weeks old and smells really burnt so what do yall think??? is it done or maybe soemthing simple??thinks mike
That was harder than H-E- double hockey sticks to read, but if you burned your fluid up that quick after a service I'm betting it's time to tear down. From what I can read of your post it appears you have 65K on the overhaul.
It sounds more like an electrical problem to me, I had similar trouble and it ended up being a loose ground at the block and some bad connections from and old MJ tranny controller. Take it back to poole or call Tim Barber at TRE diesel, he is a DTT wizard and Dtt stands behind there stuff pretty good. I broke a billet intermediate shaft and poole went through the tranny and put in new shafts at no charge to me, of course it was only about a year old at the time. Good luck with it but don't count it out till some one looks at it.
ok thinks for all the help olee is a great man i jsut hope i have voided dtt warranty by not geting the first service done till like 25000 miles..but thinks for the all the help guys i will just have olee take a look at it thinks again
Jeeptug
04-24-2007 09:22 AM
hellotbone
17
04-07-2003 06:38 PM
