DTR VP44 Powered Trucks
Old 10-29-2006, 09:54 PM
  #106
Ph4tty's Avatar
Mine too, only one =(
At least we have a 1/2 dozen 500+ ETH's
Old 10-29-2006, 10:39 PM
  #107
BigBlue's Avatar
600+hp HO's are hard to find becuase it's so hard to get them there.
Old 10-29-2006, 10:41 PM
  #108
kipo's Avatar
Let's hope Blackdiesel get's the results for the SO pump swap soon.
Old 10-29-2006, 10:55 PM
  #109
getblown5.9's Avatar
if work goes well i will be trying for 600hp on my HO with a single turbo and no drugs in april.
big sticks and a silver bullet may get me there...we will see!
Old 10-29-2006, 11:54 PM
  #110
95ram's Avatar
getblown, yours isn't technically an HO. you've got an hrvp. With the right injectors you should be able to pass 600. From my experience it doesn't matter how big of an injector you run with an HO pump, you wont see more than about 180RWHP from them.
Old 11-12-2006, 02:13 PM
  #111
CTD2001's Avatar
ph4tty
There are a few of us that now need to be updated
Old 11-12-2006, 03:06 PM
  #112
BigBlue's Avatar
Well I didn't quite make the 500 mark. Uncorrected was 533/1127. Corrected was 496/1090. That was TST on 9, smarty on 5, 155hp injectors, and a KSB-1 at 40 psi. I need the tst comp.
Old 11-12-2006, 03:09 PM
  #113
Rodram2002's Avatar
right on Big Blue! those are good numbers for 40psi of boost.
what where your egt's looking like?
Old 11-12-2006, 03:15 PM
  #114
BigBlue's Avatar
EGT's? What are EGT's? Oh, you mean that bottom gauge of mine that spins all the way around. They're fine.
I think I also figured out my turbo noise. Turns out I have a small hole in the weld on me wastegate where it's welded to my exhaust manifold.
Old 11-12-2006, 05:09 PM
  #115
dieselfan's Avatar
BigBlue, i think you could have got past 500hp mark with your smarty on SW#3, since everybody else is doing the same. the catcher program seem to rob a little hp. just a thought.
dieselfan
Old 11-12-2006, 05:21 PM
  #116
BigBlue's Avatar
Possibly, but I like to dyno in the manner in which I run on the street. I run level 5 on the smarty on the street thus I'm going to dyno with smarty level 5 that way I know just exactly what kinda power I'm making when somebody wants a piece of me. I'm not here to make the biggest numbers. I'm here to make the biggest numbers in my daily driven form. Not some made up form for the dyno. Understand what I'm saying?
Old 11-12-2006, 05:35 PM
  #117
dieselfan's Avatar
i kinda figured you would say that. nice point, i like that idea. that way when you whip someone racing you can tell them what they got beat by #'s wise.
dieselfan
Old 11-12-2006, 05:39 PM
  #118
BigBlue's Avatar
You got it.
Old 11-12-2006, 11:38 PM
  #119
Ph4tty's Avatar
11/13 update
400 club
Bob Wagner
01 Don Mach4's, DODGEZILLA/14WG, Marco's Smarty ecm tuner
401hp/833
dodgediesel4x4
2001 HO, 6 speed,Edge Drag Comp, Mach 1.5's, Super B
402 hp/899+
Cspotrun
01 auto RV275's, Smarty, TST
408 hp /827
Jaymo
00 2wd 5spd, afe, TsT pm3/Edge ez stack,edge jammer 5's
410hp/ 1015
JDGnut
2001.5 DD-DUFM, DDIII's
413hp/900+
Meatball
2002 5-spd, SLEDDIE 66, Industrial Injection injectors, Edge Comp
416 hp/798
diesel_burner
2002 h.o.nv 5600, mach 1.5, edge comp
421 hp/941
CTD_Neil
2001.5 HO 6 spd, Drag Comp, DD3's, HTB2 62/12,
434 hp/887
Beast2B
2001 ETH EDM3's, B1-2, MadECM, Edge Drag Comp
434hp/1006
More Power
01 ETH 6speed 4x4 Mach 4's Edms, Edge Drag Comp (HTT) HTB2/12 turbo,
455.1hp/ 992.8
Mike D
99 2500 CTD 4x4 Auto, SMARTY, TST PM3, F1 Mach 4.5, HTB2/64 Killer B2,
467hp/1012
MColeman
1999 4X4 auto Mach 3, drag comp, HTB2
471hp /998
12.84@102
Charlie8301
2001.5 Auto Catcher ECM/TST PM3 stack, Mach 1.5 injectors, Phat Shaft Super 62
472/990
13.4 @100.4 MPH
MSquare
2002 HO, HTT Killer B2 64/14, Drag Comp, DDP J-48 Injectors,
475hp/982
95Ram
01 Oringed head, 12mm studs, 230HP injectors, 35/3b twins, tst comp, Smarty
492hp/923tq
Ph4tty
2002 3500 DRW RWD ETH: II HRVP, Phat Shaft 64/14, Mach 4's, Smarty
492hp/976
1qckdodge
1999 auto van aaken, TST Comp on 7, II 62/12 stg 5 Jammers
496hp/998
500 club
getblown5.9
2002 HO 6spd, HRVP44, smarty, TST PM3(comp edition), DDP150's, full B1 turbo
500/1021 on #2 only
Frances212
2001 5 speed F-1 injectors, Edge comp, HRVP, Silver Bullet
501hp/ 918
Kipo
01.5' 3500 4x4 6sp: Comp (tapped)w/ S.C. tuner, 4's, ATS, PS 62/14, Fluid damper,
503 uncorrected
CTD2001
2001, 4x4, auto, Sledpuller 66,Schied Cam, DRAG Comp(EZ Mode),TST PwrMax Comp, ARP studs, Mach 6 injec., MAD ECM.
526hp/999
DTroy
2001.5 3500 Dually 5 spd. 3:55 Axle, 4 x4, Boost controller, Smarty, HRVP, Mach 4's, Blue Chip FMS, Phat Shaft 64
531.88hp/ 1008.16
Big Blue
2001 AT 4X4 TST, 155HP Injectors, Smarty, KSB-1
533hp/1127tq uncorrected
Tiger Rag
2001.5 6 spd, HO TST pm3, Smarty, M6's, BD Twins & ARP studs, II HRVP, & Helix 2
535hp/ 977
1/4 mi 4/15/06: ET 15.074 -93.42 mph
John_P
2002 TST PM3 (Comp) stacked w/ Edge EZ, High Flow Injectors, PDR HX-40
540hp/939
12.90@ 105MPH
mooseman
2001 auto, mach 4's, Edge Juice/Attitude,ats manifold,62/14 HTB2,
stage 2 w/meth.
542.4hp/1098
Bart Timothy
2001 ETH with HTB2, DD3s, Drag Comp, 30 hp shot of propane, and
Snow water/meth using windshield washer fluid.using an unmodified stock air box with rubber boot
removed, and K&N filter.
542 hp
97crewcab
99. 5spd, edge comp, 130hp injectors, HTB2 62/14
545hp Just shy of 1200ftlbs
Spicyjam
2001 6 speed Edge Drag Comp, FASS, Haisley 8x14 injectors, Fire ringed, Silver Bullet Turbo.
568hp/ 1064
600+ club
ctd89-99
1999 auto, Helix 2, mach 6,Drag Comp, Silver Bullet
600hp/ 1140
Elandon1201
2001 auto Mach 5, sps 62, II hrvp, hot juice,
564HP/ 1095 on #2
614HP 1200TQ with a little shot
bwillarTQ
2001.5 ETC, DD Mitchell'd 6spd, B1/B2 twins, MACH 5's, Edge Comp, Snow Performance water/meth injection
617HP/1200+
Mysterync
01 Dodge 2500 5spd, Edge Drag Comp, SPS66, Mach 6's, Snow Perf. stage 2, Ringed and Studed,
Smarty
595hp/ 1118
619hp/ 1186 With Water
RJohnson
02 2500 4x4 , Smarty/TST PM3 Comp, Mach 4's, BD Twin Turbos, Firerings/12mm Studs, H2O/Meth Injection
628 HP/1366
12.7/104
Timinva
2000 ETC. F1 injectors, head and cam. Drag Comp. Hx40/B2 Twins.
#2 634hp
Huff nPuff
2001 auto,Kendricks twins, Mach 6s, Edge comp drag
636.1HP& 1200 on #2 only
12.11sec @ 111mph
Mike Holmen
2002 PDR HT3B/HX40 twins, edge drag box, Mach 6,
PDR custom 24v cam, PDR stage 2 head, ARP studs
677hp/1453
Idaho CTD
2002 DTT auto, Mach 6's, Drag Comp, Cam, P&P head, o-rings, and twins.
700.1hp/ 1200+
12.03 @ 114.5mph
pro puller
auto,EEP camshaft,Hotrod vp44, Piers twins HX40 & HT3B,mach 6,Edge Comp Drag, Nitrous Express single stage system
650 on #2
701 W/ nitrous
Torque was just shy of 1400
OffShoreracer
2002 3500 Dually 4X4, Auto B1 - B2 Twins, Mitchell O-ring&Cam, 14 MM Studs, MAD Ecm, TST Comp. Version, TST HR VP-44, Mach 6 Inj, BD RAD
656 #2 only
791.52/1200+ on the bottle
Jetpilot
2002 ETC, F-1 Injectors and cam, Redline + Comp box, Steroid B-1.
#2: 610 HP
Nitrous: 832 HP
Old 11-12-2006, 11:54 PM
  #120
Ph4tty's Avatar
Originally Posted by CTD2001
ph4tty
Thats all ya gotta say bro
Congrats CTD2001 and BigBlue. I used your uncorrected numbers BigBlue because we have corrected and uncorrected numbers mixed in already so what the heck
Quick Reply: DTR VP44 Powered Trucks
