DTR VP44 Powered Trucks
#97
Do you have a scanner??
Definately devote a little time to tuning. I'd be interested to see what effect sw2 and sw8 would have.
And Congrats
And Congrats
#98
400 club
Bob Wagner
01 Don Mach4's, DODGEZILLA/14WG, Rips Allied 4 system,DTT 91% tranny, AFE Intake, Marco's Smarty ecm tuner
401hp/833
dodgediesel4x4
2001 HO, 6 speed,Edge Drag Comp, Mach 1.5's, SBC Con OFE, Super B, Scotty Duce, 4 in. straight piped
402 hp/899+
Jaymo
00 2wd 5spd, afe, Rip's 5" exhaust, TsT pm3/Edge ez stack,edge jammer 5's,SBC con fe
410hp/ 1015
JDGnut
2001.5 DD-DUFM, DDIII's, Clutch from clutch-shop.com,
413hp/900+
Meatball
2002 5-spd, SLEDDIE 66, Industrial Injection injectors, Edge Comp, Scotty II with hole.
416 hp/798
diesel_burner
2002 h.o.nv 5600, mach 1.5, edge comp, con fe
421 hp/941
CTD_Neil
2001.5 HO 6 spd, Drag Comp, DD3's, HTB2 62/12, 4" Exhaust, AFE
434 hp/887
Beast2B
2001 ETH EDM3's, B1-2, MadECM, Edge Drag Comp w/Blue Chip cover,4" exhaust,BHAF w/Mallory mount
434hp/1006
Big Blue
2001 AT 4X4 TST, 100HP Injectors, Smarty, KSB-1, DTT VB
438hp/996
More Power
01 ETH 6speed 4x4 Mach 4's Edms, Edge Drag Comp (HTT) HTB2/12 turbo, southbend con ofe 4inch exhaust, 3.55 gears
455.1hp/ 992.8
Mike D
99 2500 CTD 4x4 Auto, SMARTY, TST PM3, F1 Mach 4.5, HTB2/64 Killer B2, Scotty II w/UNI Air, 4" exhaust
467hp/1012
MColeman
1999 4X4, AFE Magnum Force, Mach 3, drag comp, HTB2, DTT 89%, 5 inch exhaust,
471hp /998
12.84@102
Charlie8301
2001.5 Auto W/ 355 Gears, Catcher ECM/TST PM3 stack, Mach 1.5 injectors, Phat Shaft Super 62, Full HTS Trans, w/ Suncoast 91% Triple disk TC
472/990
13.4 @100.4 MPH
MSquare
2002 HO, HTT Killer B2 64/14, Drag Comp, DDP J-48 Injectors, OFE, AFE, DDP 4" exhaust, AFE Magnum
475hp/982
CTD2001
2001, 4x4, 3.55, DTT auto, 5" Miter Stacks, K&N intake, Sledpuller 66, Edge DRAG Comp, wire tapped, ATS Arc Flow manifold, ARP studs, Vp44 pump cover, Mach 6 injec., MAD ECM.
485 hp/1087 ftlbs (W/Mach 6,Mustang Dyno)
95Ram
01 stock ho pump, Oringed head, 12mm studs, 230HP injectors, 35/3b twins, tst comp, Smarty, air dog, SB DD clutch, dual 4" exhaust.
492hp/923tq
Ph4tty
2002 3500 DRW RWD ETH: DD SBC, II HRVP, Phat Shaft 64/14, Mach 4's, Sm4rty
492hp/976
500 club
getblown5.9
2002 HO 6spd, HRVP44, smarty, TST PM3(comp edition), DDP150's, full B1 turbo, AFE
500/1021 on #2 only
Frances212
2001 5 speed F-1 injectors, Edge comp, HRVP, Silver Bullet
501hp/ 918
Kipo
01.5' 3500 4x4 6sp: Comp (tapped)w/ S.C. tuner, 4's, ATS, PS 62/14, Fluid damper, AFE I pg7, ARP, High Ram, Bank's 4" exhaust
503 uncorrected
DTroy
2001.5 3500 Dually 5 spd. 3:55 Axle, 4 x4, Boost controller, Smarty, HRVP, Mach 4's, Blue Chip FMS, Phat Shaft 64, AFE Intake, 5" Exhaust,SBC DD 3850,
531.88hp/ 1008.16
Tiger Rag
2001.5 6 spd, HO TST pm3, Smarty, M6's, BD Twins & ARP studs, II HRVP, & Helix 2
535hp/ 977
1/4 mi 4/15/06: ET 15.074 -93.42 mph
John_P
2002 TST PM3 (Comp) stacked w/ Edge EZ, High Flow Injectors, PDR HX-40
540hp/939
12.90@ 105MPH
mooseman
2001 suncoast auto, mach 4's, Edge Juice/Attitude,ats manifold,62/14 HTB2,
stage 2 w/meth.
542.4hp/1098
Bart Timothy
2001 ETH with HTB2, 4" Jardine exhaust, DD3s, Drag Comp, 30 hp shot of propane, and
Snow water/meth using windshield washer fluid.using an unmodified stcok air box with rubber boot
removed, and K&N filter.
542 hp/????
97crewcab
99. 5spd, edge comp, 130hp injectors, HTB2 62/14, DD clutch, FASS
545hp Just shy of 1200ftlbs
Spicyjam
2001 6 speed Edge Drag Comp, FASS, Haisley 8x14 injectors, 4" exhaust, South Bend Con FE, Fire ringed, AFE Magnum Force,Silver Bullet Turbo.
568hp/ 1064
600+ club
ctd89-99
1999 Goerend Bros auto, Helix 2, mach 6,Drag Comp, Silver Bullet, AFE intake and 4" Exhaust
600hp/ 1140
Elandon1201
2001 auto Mach 5, sps 62, II hrvp, hot juice, afe
564HP/ 1095 on #2
614HP 1200TQ with a little shot
bwillarTQ
2001.5 ETC, DD Mitchell'd 6spd, B1/B2 twins, MACH 5's, Edge Comp, FASS, Snow Performance water/meth injection,
BHAF, 5" straight exhaust
617HP/1200+
Mysterync
01 Dodge 2500 5spd, Edge Drag Comp, SPS66, Mach 6's, Banks High Ram, ATS Pulse Manifold, Snow Perf. stage 2, Intake Kit, Ringed and Studed,
Smarty
595hp/ 1118
619hp/ 1186 With Water
RJohnson
02 2500 4x4 89% DTT/Billet, Smarty/TST PM3 Comp, Mach 4's, BD Twin Turbos, Firerings/12mm Studs, H2O/Meth Injection
628 HP/1366
13.13/102.93 mph
Timinva
2000 ETC. Stock 027vp44. F1 injectors, head and cam. Drag Comp. Hx40/B2 Twins.
#2 634hp
Huff nPuff
2001 auto,Kendricks twins, Timinva's DTT trans, Mach 6s, Edge comp drag
636.1HP& 1200 on #2 only
12.11sec @ 111mph
Mike Holmen
2002 PDR HT3B/HX40 twins, ATS manifold, edge drag box, Mach 6, 5in exhaust, PDR race tranny (billet everything),
PDR custom 24v cam, PDR stage 2 head, ARP studs
677hp/1453
Idaho CTD
2002 DTT auto, Mach 6's, Drag Comp, Cam, P&P head, o-rings, and twins.
700.1hp/ 1200+
12.03 @ 114.5mph
pro puller
???? auto,EEP camshaft,Hotrod vp44, Piers twins HX40 & HT3B,mach 6,Edge Comp Drag, Nitrous Express single stage system
DTT Auto, and a bunch of other stuff
650 on #2
701 W/ nitrous
Torque was just shy of 1400
OffShoreracer
2002 3500 Dually 4X4, Auto 4.10, B1 - B2 Twins, Mitchell O-ring&Cam, 14 MM Studs, DTT Full Billet with 1480 Output Shaft, MAD Ecm, TST Comp. Version, TST HR VP-44, Mach 6 Inj, BD 5" Exh, BD RAD
656 #2 only
791.52/1200+ on the bottle
Jetpilot
2002 ETC, F-1 Injectors and cam, DTT, Redline + Comp box, Steroid B-1.
#2: 610 HP
Nitrous: 832 HP
Bob Wagner
401hp/833
dodgediesel4x4
402 hp/899+
Jaymo
410hp/ 1015
JDGnut
413hp/900+
Meatball
416 hp/798
diesel_burner
421 hp/941
CTD_Neil
434 hp/887
Beast2B
434hp/1006
Big Blue
438hp/996
More Power
455.1hp/ 992.8
Mike D
467hp/1012
MColeman
471hp /998
12.84@102
Charlie8301
472/990
13.4 @100.4 MPH
MSquare
475hp/982
CTD2001
95Ram
492hp/923tq
Ph4tty
492hp/976
500 club
getblown5.9
500/1021 on #2 only
Frances212
501hp/ 918
Kipo
503 uncorrected
DTroy
531.88hp/ 1008.16
Tiger Rag
535hp/ 977
John_P
540hp/939
12.90@ 105MPH
mooseman
stage 2 w/meth.
542.4hp/1098
Bart Timothy
542 hp/????
97crewcab
Spicyjam
568hp/ 1064
600+ club
ctd89-99
600hp/ 1140
Elandon1201
564HP/ 1095 on #2
bwillarTQ
617HP/1200+
Mysterync
Smarty
595hp/ 1118
RJohnson
628 HP/1366
13.13/102.93 mph
Timinva
#2 634hp
Huff nPuff
12.11sec @ 111mph
Mike Holmen
677hp/1453
Idaho CTD
700.1hp/ 1200+
12.03 @ 114.5mph
pro puller
650 on #2
701 W/ nitrous
OffShoreracer
656 #2 only
Jetpilot
#2: 610 HP
Nitrous: 832 HP
#100
#101
01 stock ho pump
492hp/923tq These numbers are from 5th gear (1:1). I only saw about 180 RWHP from the injectors because of the ho pump. If everything goes right I should see a little bit bigger numbers next spring.
#103
Jaymo what turbo are you running? Stock? I would skip the cam and go right for a turbo, more bang for the buck if you ask me! Cam has a high labor bill, thats why i didnt go with one
