DrPerformance Predator and EZ
Has anyone stacked these two boxes or knows what they both do? I know the Predator taps the pump and plugs into the map and ez plugs into map and data port so it seems to me that the predator is a pressure box and ez is timing and duration? If so you should be able to stack by putting the predator into map then ez into predator and factory harness into ez right? Any help would be great!
If the dr. per. does timing i wouldnt stack them. You have the right idea for hooking them up, but you want to stack a fueling only and timing box(tst,or blue chip fms with a timing box). If 2 add timing you can have problems.
Don't stack them. No worky! At least not on the 04.5 listed in your sig.
If it is on a 98-00 then you can stack them. DR P. is a pump tap only fueling boc and the EZ is a Can Bus Timing and Fuel box and they will work well together.
PimpRohr
02-24-2006 06:26 PM
greasefire
01-14-2006 10:33 PM
Mark Thomas
12-30-2004 06:06 PM
