drive pressure gauge
Drive pressure is the pressure that is built up in the exhaust manifold as the exhaust tries to push past the turbine wheel. There is a ratio of "drive:boost" that you want to shoot for. I don't know what the ratio is though.
John
John
Should work fine, just make sure you use a couple of loops of copper tubing from the manifold before you hook up to any plastic or rubber line.
I happened to have an extra westach combo boost/pyro that I used for drive pressure and post turbo egt. 38lbs of boost and 38lbs of drive pressure.
Tacsavage
02-21-2008 08:03 AM
O.T
14
07-12-2007 11:48 PM
