drive pressure gauge
Old 08-11-2006 | 03:20 PM
inline6359's Avatar
where does the drive pressure gauge go on my twins setup?
rick
Old 08-11-2006 | 03:42 PM
RowJ's Avatar
I assume your asking about the sensor probe (gauge hook up).... Same place as on a single turbo.
I use my Pyro guage tap... on the exhaust manifold. I temporarily hook up a 0-100 psi air pressure gauge to it and run 6' of copper tubing (plastic will melt) under the hood and into the passenger window. I rest the gauge on the open glove box and test at WOT.
Don't see a need for permanent gauge as readings will not change until your power level changes!
Besides, your reading air pressure off exhaust gas... would need a serious filtration system for full time use.
JMO - RJ
Old 08-11-2006 | 04:49 PM
12valve's Avatar
what is that drive pressure sensor probe? is that something i have to buy? or how exactly does it work?
Old 08-14-2006 | 08:40 AM
RowJ's Avatar
Sorry, not really a sensor. I bgt an air pressure gauge kit from Napa....think it was $15.00. Came with the copper tubing attached, and a threaded adaptor (like on our boost gauges) that fit into the pyro probe mount on my manifold.
RJ
JPR Ram
03-13-2008 11:05 PM
Tacsavage
02-21-2008 08:03 AM
blacksmokethis
11-17-2007 11:06 PM
O.T
14
07-12-2007 11:48 PM
zukgod1
13
12-01-2005 10:11 AM
