Drive Pressure
#32
The proper term is actually 'Turbine Inlet Pressure'.... which tells you pretty much what it is. It is the pressure of the exhaust gas, from the cylinders, on the inlet of the turbine wheel.
The ratio of TIP to Boost can be a critical factor in determining performance and in determining how safe a head gasket is. Most important, IMO, it is directly proportionate to, and tells you a lot about, cylinder pressures created during combustion.
Ideally, at WOT, you want a ratio of 1:1 or less (drive pressure : boost).
Woops, G1625S types faster than me.
RJ
RJ
For those that don't know exactly what Drive Ratio means and why it is important (the rest can roast me and or point out where I am mislead):
Ratio = Drive Pressure / Boost Pressure
Ratio = 40 / 35 = 1.14
Ratio = 70 / 35 = 2.0
What is more important is the actual difference in pressure between them:
DP = Drive Pressure - Boost Pressure
DP = 40 - 35 = 5
DP = 70 - 35 = 35
Explanation in a perfect world:
The energy (Hp) to drive the turbo comes from the engines exhaust gases.
At a drive ratio of 1.0 (or below) this energy comes for free. This is because even though the turbine causes exhaust pressure (the drive pressure) to go up on the exhaust stroke of the engine, the equal amout of pressure is being supplied by the boost pressure on the intake stroke of the engine. So the pressures and the forces are balanced on the intake and exhaust sides. The net load on the engine is balanced just concerning pressure and the force it exerts on the top of the pistons.
At a drive ratio of greater than 1.0 the drive pressure is higher than the intake pressure. Now because the different relative force on the intake and exhaust strokes the engine is out of balance. The forces are higher on the exhaust stroke. The engine must now use Hp to expell the exhaust gases.
The engine Hp calculation goes something like (the number for Hp Loss Factor is fictional and for example only until I can figure it out better):
Pumping Loss Hp = DP x Hp Loss Factor (caused by drive pressure)
Pumping Loss Hp = 5 x 1.5 = 8
Pumping Loss Hp = 35 x 1.5 = 53
Net Crank Hp = Total Available Crank Hp - Pumping Loss Hp
Net Crank Hp = 235 - 8 = 227
Net Crank Hp = 235 - 53 = 182
You can see how it could add up to quite a bit of Hp lost. This is made up for by adding more fuel to the engine, a higher fuel / air ratio and higher EGT's.
I don't have the exact numbers yet, but I am working on it. But as far as I have gotten, my calculations show that for example at 1000 CFM (give or take) at 2500 RPM and at 55 psi boost, my turbo set uses around 300 Hp. This is at a 1.0 drive ratio. Which is free boost, in the perfect world.
If I raise the drive ratio to 1.18 then:
Ratio = 65 / 55 = 1.18
DP = 65 - 55 = 10
Pumping Loss Hp = 10 x 1.5 = 15
Net Crank Hp = 400 - 15 = 385
If I put my HX 35 back in (and melt down my pistons as value added bonus):
DP = 70 - 35 = 35
Net Crank Hp = 400 - 53 = 347
Jim
#33
FWIW if anyone cares to check my math.
Hp Comp = Hp consumed by the compressor
Hp Turb = Hp generated by the turbine (theorical)
Hp Loss = Difference between Hp Comp and Hp Turb
I know that this is not quite right, but I attempting to calculate the turbine Hp and hence the Net Crank Hp cost of drive pressure. To do this I am trying to compare the actual boost or actual Hp Comp to that of a theorical boost or theorical Hp Comp. My thinking is that if 100% of the drive pressure were converted to boost in all cases where drive ratio is greater than 1.0 and what would the difference be in the of Hp consumed by the compressor for those cases as if the ratio were equal to 1.0.
Jim
Originally Posted by NWBombers
I am trying to work a backwards calculation on just what the Hp cost is for drive / boost ratios.
If I use this formula:
Fan Hp = P = ( Q * p ) / ( 229 *u )
P = Power in Hp
Q = Flow Rate in CFM
p = Pressure in psi
u= Efficiency coefficient (from the compressor map)
And...
I assume for the moment that a turbo is a 100% efficient in coverting drive to boost and all other factors held constant.
P1 Atmos
P2 Compressor outlet
P4 Exhaust manifold
Example 1:
P1 = 12.7
P2 = 35
P4 = 35
RPM = 2500
CFM = 777
Hp Comp = 152
Hp Turb = 152
Hp Loss = 0
Example 2:
P1 = 12.7
P2 = 35
P4 = 65
RPM = 2500
CFM = 777
Hp Comp = 152
Hp Turb = 283
Hp Loss = 130 (Seems like allot)
Example 3:
P1 = 12.7
P2 = 55
P4 = 65
RPM = 2500
CFM = 1079
Hp Comp = 332
Hp Turb = 393
Hp Loss = 60
Am I even getting close?
P = Power in Hp
p = Pressure in psi
And...
P1 Atmos
P4 Exhaust manifold
Example 1:
P1 = 12.7
P2 = 35
P4 = 35
RPM = 2500
CFM = 777
Hp Comp = 152
Hp Turb = 152
Hp Loss = 0
Example 2:
P1 = 12.7
P2 = 35
P4 = 65
RPM = 2500
CFM = 777
Hp Comp = 152
Hp Turb = 283
Example 3:
P1 = 12.7
P2 = 55
P4 = 65
RPM = 2500
CFM = 1079
Hp Comp = 332
Hp Turb = 393
Hp Loss = 60
Jim
#34
The drive pressure should be less than the boost?
Is there a guage on the market that you can buy that won't soot up,
Jim - Your getting up there with some of HOHN's threads. Need to review it several times for it to sink in.
RJ
#35
Chase a few threads where some one has upgraded a turbo. Often they might say that EGT's are lower and they make more Hp for about the same boost.
Where does that Hp come from?
Jim
Jim
#37
Yup, Cooler compressed air = denser air = more O2 molecules = more hp for a given boost level.
General rule of thumb.... guys running bigger single turbos over 42-45 psi are getting "expansion' boost, not "compression" boost. The expansion boost comes from over working the compressor and heating the charged (compressed) air. Gives fun readings on the boost gauge but actually hurts HP.
RJ
RJ
#38
Bingo!
My curiosity about drive pressure comes from my experimentation. I have an exhaust brake. Any time exhaust (drive) pressure gets to be above about 15 psi it can noticeably slow the truck down. Of course it is not linear. For example, 20 psi at 1500 RPM is not the same as 20 psi at 2000 RPM. As far as braking ability goes.
Thats why I think drive ratio is a talking point, but the difference in drive pressure over boost pressure is where the Hp is lost (or gained).
A ratio of 4.0 most would say it sucks, but:
Boost = 1
Drive = 4
DRatio = 4.0
DPressure = 3
Nada, who cares.
Which is totally different than a ratio of 1.5 where:
Boost = 40
Drive = 60
DRatio = 1.5
DPressure = 20
Now you have significant exhaust braking, contradicting everything going on over on fuel/air side of the engine that is trying to make Hp.
Now consider the Hp loss:
DPressure = 20
RPM = 2200
HpLoss = xxx
DPressure = 20
RPM = 3400
HpLoss = XXX
Jim
Boost = 1
Drive = 4
DRatio = 4.0
DPressure = 3
Nada, who cares.
Boost = 40
Drive = 60
DRatio = 1.5
DPressure = 20
DPressure = 20
RPM = 2200
HpLoss = xxx
DPressure = 20
RPM = 3400
HpLoss = XXX
Jim
#39
RJ
RJ
Jim
#40
Well, I got the permanent TIP gauge kit installed on the '05 today at the shop...
it sure is a lot of fun to watch a NEW gauge!
I was surprised at the TIP levels I observed - 70 PSI!
Kind of puts HG issues in a whole new light, huh?
#41
How come no one ever talks about the thermodynamic nature of the exhaust gas as it travels out of the chamber into the turbo. sure the piston pushes the exhaust out into the head, but the hot gas is still expanding as it travels down the manifold, which in my mind effectively drives the turbo. The heat of combustion is extracted by the turbine. Am I way off base here or something.
#42
Hey, we (NTxDTR#8) discuss the thermodynamic properties of the exhaust pulses exiting the manifold plenum through the turbine on a regular basis!
#43
My current theory, if you look at the problem as an individual cylinder. Any time drive is greater than boost the added pressure acts as a detriment to engine performance. Because up to then, the vast majority of the Hp needed to drive the turbo comes for free in the form of waste exhaust heat by the engine.
For my truck:
02 ISB
Displacement: 359 cu. in. (5883 cu cm)
Bore x Stroke: 4.02 x 4.72 (102.1 x 119.9)
Compression Ratio 16.3:1
Work = W = F * D
P = Pressure = Drive - Boost = 60 PSI
F = 761.54 Lbms (Cylinder Area = 12.69 square inches)
D = .39 Feet (Stroke)
W = 299.54 Ft-Lbms (What it takes to push 60 psi out of one cylinder)
There are 3 exhaust strokes per engine revolution.
So if:
RPM = 2500
W per revolution = 898.62 Ft-Lbms (299.54 * 3)
W per min = 2,246,544 Ft-Lbms per min
W per Sec = 37,442.4 Ft-Lbms per sec
1 Hp = 550 Ft-Lbms per sec
Pumping Losses = 68.08 Hp
Thats drive pressure at work. Theory valid or not?
Jim
#44
A guy over on NWBomber's calculated his twin set Hp using this method. The change in enthalpy calculation is over my head, but he could do it.
He came out at around 300 Hp at WOT. This is about what I came up with but I used compressor Hp by first calculating CFM.
Compressor Hp = Turbine Hp
IE:
P = Power in Hp
p = Pressure in psi (boost)
u = Compressor Efficiency Coefficient (from the compressor map)
Jim
2006BLKMegacab
07-03-2011 08:31 AM
cincydiesel
06-11-2008 01:55 PM
skymiles
12-21-2006 10:05 PM
Hummin Cummins
02-11-2003 12:14 PM
Copenhagenjunkie
12-27-2002 05:45 PM
