Drive Pressure
Old 03-20-2007 | 08:21 PM
CTD01's Avatar
Drive Pressure
How do you measure this and what are good numbers? Thanx,
Paul
Old 03-20-2007 | 08:41 PM
Big Smoky's Avatar
Use your EGT port and use some copper tubing and a boost gauge. With a 62/12 I imagine your drive pressures won't be too bad. when you start getting 55-65 psi, thats when I think it's getting a little high.
Old 03-20-2007 | 09:01 PM
G1625S's Avatar
Yup, drive pressure is the exhaust pressure that builds up in the exhaust manifold. You don't want to see over 1:1 between boost and drive pressure. For example, if it takes 20psi of drive pressure to make 15psi of intake manifold boost, well, that's bad!
Old 03-20-2007 | 09:10 PM
BCSCUMMINS's Avatar
Paul
Is your turbo 71 series ss 62/12 or just the regular htb2. If it is the 71 series the drive presser is .8 to 1 at 55psi. I think the htb2 62/12 is 1 to 1 at 50psi
2006BLKMegacab
07-03-2011 09:31 AM
cincydiesel
06-11-2008 02:55 PM
skymiles
12-21-2006 11:05 PM
Hummin Cummins
02-11-2003 01:14 PM
Copenhagenjunkie
12-27-2002 06:45 PM
