Drilling manifold w/engine running ?
Old 08-02-2004 | 07:37 PM
BigBlue's Avatar
I've done to different installs on gauges. Both left the turbo on the truck and used the grease and magnet method. I have 50K miles on mine and it spools great. The other guy has about 10k on his and his is doing great.
Old 08-05-2004 | 10:58 PM
Garz's Avatar
Someone told me to stuff a shop rag in the manifold up to the point where u drill and tap. Pull it out when ur done and shop vac the hell out of it for good measure. Worked fine.
Old 08-06-2004 | 01:24 AM
elkbelch's Avatar
2 foot extension from under side for back bolts no problem.
Old 08-06-2004 | 01:39 AM
BoostdCTD's Avatar
Yes I was serious, doing it while running is pretty common. Infidel's method is probably a little safer yet. Truly the best way is to drill and tap it with the manifold off the vehicle but that is a little bit of work. I don't think I'd trust just the grease alone to catch all the chunks.
bakerroc
04-07-2008 10:36 PM
2006zo6pilot
11-22-2007 12:11 PM
Remnik
10-26-2006 08:36 AM
PZM123
04-04-2006 06:24 PM
wadem
10-03-2004 01:54 PM
