Drilled egt hole question
I am buying a used manifold, that has an egt hole drilled and tapped in it. This should not cause any problems with leakage, considering I have an exhaust brake, should it? Are the drilled ones more prone to cracks?
Thanks
Thanks
are you going to use it for the egt gauge? or just plug it? either way it shouldnt matter
lots and lots of people put the probe for the pyro in the manifold.
it is a tapered thread so no need to get out the breaker bar to tighten anything down.
jiMMy
jiMMy
GO 4LO
11-01-2005 02:59 PM
Dave88LX
09-13-2005 10:45 AM
Dodgezilla
21
02-03-2004 04:26 PM
